Question about Nokia E75 Cell Phone
Nokia e75 stuck in offline mode - Nokia E75 Cell Phone
  • 4 Answers
SOURCE: Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Posted on Jan 14, 2009
adnanbhatti
  • 1188 Answers
SOURCE: I have a e75 nokia, I somehow managed to change to
You may have inadvertently selected the Offlkine profile. Also make sure a sim card is present in the phone. Then follow this procedure:
Select Menu > Control panel > Profiles.
To change a profile, select a profile and Options >Activate. Select a profile other than the Offline.
Posted on Dec 10, 2009
shibuda
  • 1812 Answers
SOURCE: my nokia e75 is in
Just follow the steps
Make a backup of contacts in your another sim.
Try to Restore factory settings
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Posted on Jan 17, 2011
sajprus
  • 109 Answers
SOURCE: my nokia e75 is in offline mode. i cannot received
Tap the power button once (do not hold it too long, because it will turn your phone off). Just choose any profile, and your phone will go to online mode. You can switch it anytime to offline mode, in case you want to use your phone and be unavailable at the same time, by doing the same thing - tapping the power button, and selecting offline mode/profile.
If this helps, please rate. Thank you.
SOURCE: i am having an nokia
Check your sim compatment to see that the sim is properly fixed and as for the offline press the read button on your phone it will bring out the options just click on online on the options and your phone will be back to online
Posted on Feb 07, 2011
Nokia E50 Stuck in offline mode
i had nokia e 50 stuck in offline mode pls help me out
Aug 23, 2011 | Nokia E50
My nokia E75 is stuck in offline mode ! the network don't work and I can't dial up any thing numbers are stuck too ! please help me !
Its very simple just press *#7370#.
Then it requests for the security key whic is 12345 by default or enter your security code if you have changed the security code..
Please note that all the data on your phone will be deleted so kindly make a back up.
Kindly rate us in fixya if i am helpful
Feb 13, 2011 | Nokia E75 Cell Phone
I am having an nokia e75 mobile.... Inspite of the sim being inside the mobile, its displaying that its in Offline mode and showing an error "Insert SIM"... please help me the method to sort...
Feb 07, 2011 | Nokia E75 Cell Phone
My nokia e75 is in offline mode. i cannot received text and calls. how can i change my mode to online. thanks
Jan 17, 2011 | Nokia E75 Cell Phone
My phone is on offline, i try to change the profile then is telling to insert sim whereas i have sim card on the phone
change the offline mode,then
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
http://www.superunlockcodes.com/nokia-e75/rs12wp9/
Dec 22, 2010 | Nokia E75 Cell Phone
My phone is a Nokia E75. The problem is there is no way to switch it back from offline-mode to general. (as to what I found on the net it seems to be a well known issue but I didn't find a solution......
update your phone firmware to latest one,update solve many bugs and issues,you can download nokia software updater from nokia website europe.nokia.com
hope this will be help
Nov 27, 2010 | Nokia E75 Cell Phone
Hello i need master code for nokia E75 p help me
NOKIA E75 falls under BB5 group..and its master code can't be generate by master generator.. but for this solution you can try it..
Nokia BB5 Security mastercode reset
These newer BB5 phones require software to reset the security code:
Nokia 3250, Nokia 6125, Nokia 6131, Nokia 6270, Nokia 6280, Nokia 6630, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 7370, Nokia E50, Nokia E60, Nokia E61, Nokia E62, Nokia E70, Nokia N71, Nokia N72, Nokia N73, Nokia N80, Nokia N90, Nokia N91, Nokia N92, Nokia N93,
Nokia BB5 security code reset procedure:
* Connect your phone via USB cable in pc mode
Sep 04, 2010 | Nokia E75 Cell Phone
Dec 10, 2009 | Nokia E75 Cell Phone
Nokia E75 Cell Phone Logo
159 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
