I can get internet but can not get a diling tone .even if i unplug broadband
  • 591 Answers
Call your Internet Service Provider the modem is probably defective...
Posted on Apr 09, 2011
One tel sigma 2200. No dial tone.
are you using dsl broadband this could interfere . Type of signalling may be a problem. If multi tone or decadic on phone line does not match phone settings but I would expect you hear dial tone. do you have cable plugged into a phone socket it could be a internet rj45 socket.They look the same at the wall especially in an office environment.
May 08, 2014 | Lands Phones
Is serching and not working
second handset keeps searching and has no dile tone
Nov 29, 2013 | Emerson DECT 6.0 Expandable Cordless Phone...
One phone will notget a dile tone
I have a uniden dct626-2 and when talking the other party cannot hear me?
Oct 18, 2009 | Bell 36282M4 Twin Cordless Phone
I cant connect to the internet i get code 680 the modem can not hear the dile tone iv tryed to uninstall the driver and install it again and iv done an earler restore point this is not helping do i need a...
You may not have the phone cord connected correctly to the modem. Some modem's will have two jacks, one for the phone line and another that you can connect your phone to. Make sure it is securely connected to the wall and modem. I would also use a phone to test the phone line and make sure it is working.
Jul 06, 2009 | Computers & Internet
My printer will not receive a fax saying "phone off hook". There is no phone on the HP2410, and the phone is on the hook.
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver is off the hook (the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message. Checking the phone line The most common reason for this message is when a dial-up modem is accessing the Internet on the same phone line. Just as two phone calls cannot come in at the same time, two devices cannot use the phone line at the same time. If a broadband modem (such as DSL or ISDN) is on the same phone line and the message appears all the time, please contact your Internet provider for assistance. Even if a dial tone is present when listening to the phone line, the HP product may detect the broadband data connection at the higher line frequencies. Broadband modems must have a line filter installed to work correctly. Contact the telephone company for assistance. Please follow the directions below to verify functionality.
  1. Verify that the phone cable going into the HP fax product from the wall jack is a two-conductor cable type, not four-conductor. A two-conductor cable, like the one that ships with the HP product, has two copper leads in the connector. The connectors are usually clear, making it possible to see how many copper leads are inside the cable. Replace a four-conductor cable with a two-conductor cable.
  2. Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. If the message persists, see the "Problem still exists" section below.
  3. Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Continue with the steps below if a dial tone is present.
  4. Plug the phone cable back into the HP product and hang up any phones with a lifted handset.
  5. Disconnect, one at a time, other phones and devices using the same phone line. Check the HP product display after disconnecting each phone or device. If the message clears after disconnecting a phone or device from the line, the problem is with that phone or device.
  6. If the message still exists after unplugging all other phones or devices, see the "Problem still exists" section below.
  7. Problem still exists
  8. If the problem still exists after performing the steps above, the line interface unit (LIU), the part that the phone line plugs into, may be defective or the HP product may need to be serviced.
Jan 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
We lost the manual for our 25982EE3-A and need to change to tone
From the Manual!
Tone/Pulse Dialing
NOTE: This setting may be made only with the base.
1. Press the menu/flash button until 41TONE 2PULSE shows in the display. 1TONE is the default.
2. Press the caller id (9 or :) button or the touch-tone pad to scroll to 1TONE or 2PULSE.
3. Press mute/menu to save. You will hear a confirmation tone.
Here is a copy of the manual.
http://www.home-electronics.net/ge/pc/IB/25982EE3_IB.pdf
Jan 16, 2009 | Uniden Cordless Phone
Ford focus diles stoped working
have you checked any wires on your altenator
Jan 02, 2009 | 2000 Ford Focus
Phone off hook message
hi,
Jun 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
NO DIAL TONE
If you are using the same phone line on broadband and fax, you may need to use a filter for the fax line. Also make sure the phone line is plugged into where it says "line" side of the fax and not where it says phone.
Hope this helps...
Jun 14, 2008 | Office Equipment & Supplies
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
