Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
Where do you put petrol and oil,and how to mixs it
Get a gallon gas can..put half gallon gas in then add 2.6fl ozs oil..then top can with more gas till full shake it and there is your mix ready to use
Posted on Apr 16, 2011
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Harry Prisma 37 Petrol or mix?
your question was put in the sewing machine catagory,
if you put it in the lawnmower catagory, then someone can help you
with a answer
Jun 02, 2012 | Sewing Machines
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
What is proper gas mixture?
fuel mix ratio is 50:1 using good quality 2 stroke oil
ie if you mix 20 mils of oil for every 1 litre of petrol that you mix
that is 50:1
or if you want a 5 litre mix put in 100 mils of oil into a clean petrol container 1st then put in 5 litres of fuel only and give good shake
cheers paul
Aug 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I inherited a Rancher 50 20" chainsaw from my uncle only noone know the oil gas mixture.
using good quality 2 stroke oil use ratio 50:1
that is 20 mils of oil per 1 litre of petrol that you mix
put oil in can 1st then add petrol and give good shake
so if mixing 5 litres pour in 100 mils of 2 stroke oil and add 5 litres of fuel only
cheers hope it helps
Aug 07, 2010 | Husqvarna Garden
What type of petrol and oil to use for a sabre 3350 chain saw
The best thing to do is see if your Mom has the operators manual. If not, the best thing I can do is guess. Most chainsaws are two cycle. This means that fuel and oil has to be mixed. There is a formula that you can find on line depending on what ratio is needed. The other chamber that says oil on it is the tank for the Bar Oil. That is the oil that lubricates the bar and chain as the machine is running. You should get some oil that is formulated just for bar lube. Do mix fuel and oil, do put in bar oil...Good luck...Lee
Aug 31, 2009 | Garden
Do you mix petrol with 2stroke oil
Yes if you have a 2 stroke. You will need to look at the manual, or somewhere on the bike for the ratio.
Jun 13, 2009 | 2005 kawasaki KLX 110
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
115 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
