My dehumidifier has stopped collecting moisture from a (Usually) damp atmosphere. I have cleaned the filter.
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Apr 09, 2011
Our DeLonghi condensation removal system no longer removes moisture; it appears to run fine; the lights indicate all systems are on. I have cleaned the filter; cleaned the tube; disconnected the tube; set...
heatman101
Aug 28, 2011 | DeLonghi DH100P Dehumidifier
My dec14 has stopped prodicing water in the tank but seems to be working normally. I have damp patches on my walls so there is moisture to collect. Why has it stopped working please?
heatman101
Aug 12, 2011 | DeLonghi Dehumidifiers
Dehumidifier does not collect moisture. cleaned the filter and still doesn't work. fan works fine.
heatman101
Jun 22, 2011 | Kenmore Dehumidifiers
I have a WDH 610HC de humidifier I bought it in Feb 2008 it has suddely stopped taking in moisture from the room, I have checked and cleaned the filter, is it worth getting repaired?
heatman101
May 02, 2011 | Dryers
The dehumidifier is running but no water is being eliminated from my damp basement
Florence, the air intake filter on the humidifier probably needs to be removed and cleaned. When they're dirty, the unit has to strain to take in the damp air. Turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to remove the filter. Once the filter has been cleaned and dried (if necessary), plug the dehumidifier back in, turn the Master ON/OFF Switch to ON and set the controls as you normally would. After about an hour or more, you should notice water collecting in the bucket.
Hope this helped you solve the problem.
Apr 27, 2011 | Fedders Dehumidifiers
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
My Delonghi DEM10 compact dehumidifier has stopped collecting water. The unit starts and runs fine with no change in noise, but after I left it running for 3 hours in my bathroom, it had not collected any...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 30, 2010 | Heating & Cooling
My dehumidifier is about a year old. Plugged it in and it ran for 6 hours but no water in bucket. Cleaned the air filter and no moisture taken from a very damp basement
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 24, 2009 | Danby DDR401 Dehumidifier
Dehumidifier stopped working,then started up,but making strange buzzing sound and does not collect any water
Try cleaning the coil and filter. They may have collected alot of dust and this could have caused the issue. If it is still doing it after you clean it the issue may be thecompressor. If the compressor is bad it may be cheaper to pick up a new unit. I recommend picking up one that has an energy star rating. They are usually made of higher quality materials and will save you some money on your electric bills. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 23, 2008 | LG LD65EL Dehumidifier
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
