Question about Microwave Ovens
Use of Micro Max microwave hamburger / sandwich grill
2 Suggested Answers
  • 8909 Answers
SOURCE: need instruction manual for
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 23, 2010
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Panasonic microwave grill not working
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Dec 04, 2012 | Microwave Ovens
Need instruction manual for Nordic ware microwave micro max hamburger/sandwich grill
I hope this helps.
Dec 23, 2010 | Microwave Ovens
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 15, 2010 | Whirlpool MH6141XK Microwave Oven
Does not cook even . put 2 items in cooker one well done other one half,
were both items the same density? Was one maybe thawed more that the other? A microwave cooks by rapidly heating the water molecules within the product that you are heating. If you heat two of the same product, it should cook them both evenly, however say you put in a frozen hamburger and a thawed hamburger, the frozen one will only begin to defrost while the thawed one will actually cook
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
How to Remove an OTR Microwave from the wall
first you need to take the grill off the front of the micro there should be two screws on the very top of the unit that allow you to take the grill cover off there also should be two screws in the cabinet above the micro that hold the unit in place some models have a silver hook or latch on the left side that you pull forward to release the unit from the back plate do not pull on this till you have taken out the two set screw on top of the cabinet after doing this the micro should come down
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
125 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
