Question about Rohl A3608/11LMAPC Single Lever Country Kitchen Faucet with Extended Spout...
When I released the button on the hand-spray, the water did not divert back to exiting from the faucet. Water will no longer come out of the faucet, just the handspray.
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 49 Answers
SOURCE: No water passes from faucet to hand sprayer
try soaking it in some CLR calcium lime and rust remover .
Posted on Mar 18, 2009
  • 92 Answers
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
bearsfan7538
  • 119 Answers
SOURCE: when using the hand sprayer water still comes out
This faucet is notorious for this problem it is a design flaw that the manufacturer will not own up to either live with it or as I recommend to my customers replace the faucet with a better more reliable brand.I wish there was a better solution
Posted on Nov 15, 2009
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
Apr 21, 2012 | Moen Plumbing
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Hand held roman tub spray no longer works - no water
It is possible that it's just in the handle where the diverter is located. It just may be stuck closed and will not open when the button is pushed. You may want to contact the manufacturer for trouble shooting info and the possible cause. They will be able to help you determine what the model number is by your description of the faucet and handheld unit. Where we do not have access to that information.
Apr 02, 2009 | Home
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Rohl A3608/11LMAPC Single Lever Country Kitchen Faucet with Extended Spout... Logo
48 people viewed this question
Top Rohl Plumbing Experts
Donni Steen
obsteiner
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
