Question about Maytag MER5775Q Electric Kitchen Range
Part number 5701M760-60 (clock/control pane) on my Maytag range Model merh752bab has pushed in on the right hand side. It still works, but is no longer attached to anything on the right. How do I reattach this part?
SOURCE: No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Posted on Oct 06, 2007
Dipu007
  • 2110 Answers
SOURCE: F9 on Maytag range MGS5770ADB
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Dec 23, 2008
tzweeb
  • 318 Answers
SOURCE: Hot Surface Light Stays On
you do have a top burner sensor that has failed. the hard thing is to figure out which one. most of these units have a 5 year part warranty, but you have to pay for an authorized servicer replace it for you.
if you want to figure it out yourself, you will have to find which of the wires, from the burner sensor, controls the indicator light. its not hard as it is usually the smaller one. each burner has a sensor and if you are certain you can work with the electricity on, its just a process of elimination.
unplug the unit from the wall, then take off the wire from 1 burner at a time, tape it off, to prevent shorting to ground, then plug back in and see if the light has gone out.
then you can order the new sensor, but on some models, you have to get the whole burner and sensor assembly.
Posted on Dec 28, 2008
jsrock516
  • 5911 Answers
SOURCE: How do I set the clock on a Maytag gas range, I
If your range is the same model as you posted this question under, the time is set by pressing the "CLOCK" button. The word "TIME" will begin to flash on the display. Using the keypad, press the corresponding numbers of the current time.
NOTE: If the oven has been programmed, or is in use, you cannot change the time. Cancel all other functions before attempting to set the clock.
If the model number is not correct, please post back with your correct information so that I may be able to provide you with better assistance.
Posted on Nov 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: what is F1 on my maytag range model mer5570acw I
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
$%^Y
Posted on Oct 01, 2010
Maytag electric range buzzes and resets clock when key is pressed
the membrain has a almost stuck key / if the clock has w warped face . then some of the buttons are almost closed. asn causing some problems . it won't get better in time if will fail . and the clock will have to be replaced . .. mm hope this helped .
Dec 12, 2009 | Dishwashers
I have a 1950'S GE range and can't locate the Model number This range has 4 burners, the oven has chrome on the inside of the oven door. there are slide out compartments under the oven and on the left side...
I believe the model number is inside the drawer to the left of the oven near the top on a metal plate. it wont say model number as it was a catalog number. it will say cat. no
Nov 07, 2009 | GE Kitchen Ranges
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Faceplate on a new Maytag stove pushed in...
Appliancepartspros.com has an excellent exploded view diagram of your stove that you can reference. Just type in the model number you provided and look under the Control Panel/Top Assembly section. I believe you may have a broken clock bracket (item 2), but you will need to remove the BACK of the control panel to access everything to inspect. Make sure you UNPLUG the stove before servicing. If you have questions, let me know. I hope this helps you.
May 05, 2009 | Maytag MER5770 Electric Kitchen Range
Dec 28, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag MER5770AAW Oven
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
Sep 08, 2007 | Kitchen Ranges
Where is the model number on my Range?
As you are facing the range, there should be a metal plate (held on by one screw) on the left hand side behind the console. Model and serial number should be located here. On some models the information will be along one side of the oven door opening, or bottom drawer. Hope this helps you.
Aug 11, 2007 | Maytag Model MER4351AAB
Maytag MER5775Q Electric Kitchen Range Logo
54 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
