Question about Garden
How do you remove the rear axle on a snapper rear eninge riding mower to replace the protective rubber boots?
  • 653 Answers
SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
Posted on Apr 07, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 125 Answers
SOURCE: snapper comet rubber drive
Get a new drive wheel.
Put mower in neutral.
Stand mower on rear supports.
Remove the four bolts holding the old wheel.
install new wheel.
Posted on Jun 16, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Snapper rear engine riding mower. Mod#28085S
If one goes to the starter, the other has to come from a 12 volt source, either ignition switch or battery
Posted on Oct 04, 2009
mickey813
  • 472 Answers
SOURCE: I have an older Snapper lawn mower that just stopped moving.
your trans axel has striped out in side you will need to get that in to the shop let me know if this helps you or if you need to find a shop
Snapper rear riding mower won't move while in gear
yes your looking at the problem easy to change close the vent on the fuel cap remove the battery and lift it up and stand it on the rear bumper tubes (thats what there there for) after replacing you might need to move the links for the cable up near the pedal
Jul 11, 2012 | Garden
Need to adjust rubber drive clutch on 30 inch snapper mower
there are small metal beads on the cable near the pedal you move to the other side of the pedal if the friction wheel is warn you will need to replace it only 3 nuts hold it on just flip the mower up on the rear bar and take it off no fancy tools needed
Jun 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
Where is the safety switch for the brake on a snapper riding mower
it depends on the model you have a front engine it would be near the pedal on a rear engine mower it is near the rear axle
Jun 09, 2012 | Briggs & Stratton Garden
Snapper riding mower runs but wont pull itself
first check the friction wheel that drives the rear axle then look at the cable adjustment you may need to move the small rings around the pedal if all that looks good loosen the pulley assem away from the engine closer to the axle
May 16, 2012 | Garden
How do you replace the tramsion sleeves in snapper?
unbolt the hub the remove the side plate on the side you need to change not as hard as it sounds like 7or 8 bolts
May 11, 2012 | Snapper Garden
Old snapper riding lawn mower with the handlebars
Usually the drive disc . Look under mower at rear, you will see a wheel with rubber ring on outside diameter. I think, it is four small bolts holding it on. Take off and replace, will usually solve problem.
Mar 23, 2010 | Garden
I have an older Snapper lawn mower that just stopped moving while I was mowing grass. I have put a new drive plate on it (the one that has the rubber around), but that didn't help it. When I stand the...
Oct 04, 2009 | Garden
Snapper comet rubber drive
install new wheel.
Jun 15, 2009 | Garden
Garden Logo
312 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
