Question about Kenmore Washing Machines
When it is spinning the tub shake and seem to be moving
    Brigadier General:
  • 6,277 Answers
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 09, 2011
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
Maytag top load washer shakes. The plastic tub seem to be the problem. I took the front off and watched it spin. The tub seems to want to lean to one side and spin out of round moving up and down. All...
Seems with your observation that the tub is out of shape and so it might be wobbling when it runs. So the only option is to change the tub with a new one but the cost must be confirmed to decide between a new tub or a new washer.
If you can get a salvaged tub it will be economical.
Sep 26, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Vibrates, shakes and moves around and has a lot of noise while spinning. It has been leveled and the floor seems sturdy enough.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Jul 01, 2009 | Washing Machines
Kenmore washer stock no. 22642 shakes terribly during spin cycle
There is a suspension plate under the tub.
It also has 3 pads on it to support the tub.
There are springs attached to support the angle of the tub.
Check all these parts and repair or replace as necessary.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Washing machine
WASHING MACHINES HAVE SPRINGS ON THE BOTTOM OF THE TUB THAT ARE MENT TO KEEP IT FROM SHAKING, LIFT THE LID BY INSERTING A SCREW DRIVER SIDE WAYS BETWEEN THE LID AND THE FRONT THEN TURN THE SCREW DRIVER, NEXT UNDO THE SCREWS ON THE RIGHT AND LEFT HOLDING THE FRONT ON TO THE MACHINE, NOW IT WILL SLIDE OFF AND YOU CAN SEE THE SPRINGS
Dec 18, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
11 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
