Question about Echo Rapid Loader, Trimmer Head
String stuck inside of of head how to remove - Echo Rapid Loader, Trimmer Head
String is inside c430 trimmer and won't bump out.
then take it apart and get the string out thru the hole(s) again
Aug 09, 2016 | Garden
How do I get the trimmer head open?
Turn the knob in the middle of the head anti clockwise and the string reel should come out.
Aug 21, 2015 | Garden
How do i remove the head to replace the string on a Murray M2500 trimmer?
How do i remove the hend of the weedeater it is stuck on there. I believe it is stripped
Sep 08, 2014 | Garden
Cutting string is stuck inside head
The head will have to be pulled off by taking the nut off of the bottom and then take the spool off and resting the spool. If the string is new it may be the wrong size string.
Jun 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Spool cap struck
Well you are going to have to cut off the cap off the get to the bolt head inside the cap. Use a hacksaw to cut downward to cut off the cap, this will get you to the bolt head. Depending on the color of the cap will determine whether it is a left threaded bolt or right threaded bolt. Red means left turn clockwise to remove, black means right turn counter clockwise to remove.
Good Day
Oct 07, 2009 | Poulan Garden
The string in the spool of the weed eater is stuck. How can I remove the string and how can I avoid this problem in the future? I'm using the pre-cut strings. Thanks
Sounds like one of the loops is over the one being fed out. Does that make sense? I hope so. If one of the windings of string is over another, it makes it hard to unwind. Maybe if you were to put on a glove and really pull on the string, it would start to unwind. Other than that, pull the head and check the string. Good luck...Lee
Sep 20, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can not remove head to install new string...HELP
you need to turn the knob on the bottom clockwise-also if that doesnt work it could be just stuck try using a pair of vise grips to loosen
Aug 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Jun 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Echo Rapid Loader, Trimmer Head Logo
410 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
