Question about Bosch Nexxt 300 Series WFMC2201UC
What does E02 stand for on a Bosch Nexxt 300 Series?
  • 27 Answers
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Posted on Jun 26, 2007
SOURCE: Bosch Nexxt 100 Series washer
Bosch Nexxt series 100 place clothes in machine start add detergent as always machine begins to add water for about 30 seconds then stops , sometimes stops and sounds like it is trying to drain sometimes just stops and won't unlock door even if you turn machine off. Sometimes if you switch from hot to cold washer will work just fine for a couple of days then back to just stopping.
Posted on Sep 23, 2008
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
  • 3 Answers
SOURCE: Bosch Nexxt 800 series dryer E01 error
If you are using dryer sheets...stop. They clog your linter filter. Use windex to clean the filter and a soft bristle brush....also check to ensure your dryer vent is clear using a shop vac to clean or a vent brush.
Posted on Dec 01, 2009
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I am getting an E02 error. It has been running for about a half an hour and clothes is still dry. Water appears to be going in, but not sure to where???
I've encountered this a few times. I still haven't been able to find out what the E02 stands for, but if you unplug the machine, wait 30 seconds, then plug it back in, it seems to work fine.
Sep 30, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Error code E02 on washing machine-3 beeps -machine stops cycle
you should buy a new one..
check this one..
http://www.washingmachineadvisor.com/
Jan 13, 2010 | Bosch Nexxt 300 Series WFMC2201UC
I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
Jan 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
After about 5 minutes into a wash cycle, the error "E02" is displayed and the wash cycle stops. What does this error message mean? It isn't in the book that came with the washer.
I just had this problem. My water supply (hot ) had been turned off since my husband used it to fill our hot tub. Other causes were-supply hose kinked,strainers in supply hose clogged, water pressure too low. Hope this solves your problem!
Jan 09, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 Series WFMC2201UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
