Whirlpool AWO/D 4505 Washing Machine
The 'Clean pump' light has come on, on the above washing machine and it will not work. Any idea how to clean the pump or do I need to contact a whirlpool engineer?
  • 3 more comments
  • Anonymous Nov 23, 2008
    I have the same problem - can anyone help??
  • jorge_jurado
    jorge_jurado Apr 15, 2013
    Same. It won't drain
  • Marie Purcell Apr 22, 2013
    I have the same problem help please
  • Anonymous Mar 12, 2014
    Awo/d 4505 washing machine the clean pump red light came on so cleaned the pump it yet it is still not working what can I do before I have to call someone in thanks
  • Anonymous Mar 15, 2014
    The motor or pump is very noisy on my new whirlpool washing machine is it normal I have only had it on quick wash three times still far do I need run it on a different programme to sort this out the delivery man said it was normal it was the pump adjusting is this right
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
  • 7 more comments
  • leannet Jul 18, 2010
    I had same problem with my machine. It was also making a really loud clicking sound and would not drain. I followed the above instructions and now it is working brilliantly. x
  • umusaale Oct 19, 2010
    Thanks for this advice. It just solved my problem!
  • mmoustaka Dec 02, 2010
    Thank you thank you.....did the trick! A warning though, if there is water in the machine it pours out of that area........Maria
  • daviespider Jul 21, 2011
    The water pours out if it stops in mid-cycle, it took a wee while draining very awkward but working perfectly now, thank you!
  • lmwilkinson Aug 14, 2011
    Today- I have had this machine for about 4/5 years and I had a load of bedding to wash. In the middle of the first load it stopped and the red light came on to say the pump needed cleaning! My partner was away at work so I looked on this web page, found my answer and set about doing the job myself! I now have a working washing machine and a very clean kitchen floor - but the day is saved!!
  • cull_kat Feb 22, 2012
    Sweet!!!! Just fixed my machine all by my self:) thanks a mill :)
  • trinawheeler
    trinawheeler Apr 27, 2012
    I just had the same problem, I couldn't get the machine to drain but thankfully there wash't too much water! 2 hair clips, a sticker and 5p later the machine is working again! Yay! Thanks for the advice!!!
  • pochsner
    pochsner Jul 27, 2012
    Perfect!...thanks Simon...that was easy after all. I removed $3.30 in coins, a pencil, and a lollpop stick!. Kids grr!...thanks a lot. Mine was the Whirlpool WFS1073DD by the way but your description was exactly the same for it.
  • jjkerr81
    jjkerr81 Sep 21, 2012
    Fixed by following the above - thanks!!
Posted on Jun 27, 2010
Clean oump light on, how i fix it?
Posted on Sep 24, 2008
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
I need to clen the pump on a whirlpool washing machine awo/d 4505
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Sep 22, 2009 | Washing Machines
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Feb 27, 2009 | Whirlpool Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
5,803 people viewed this question
Top Washing Machines Experts
