Question about Hotpoint Refrigerators
Water leaks out of the freezer compartment mabye once a day but all food still frozen
    Problem Solver:
  • 15 Answers
You have a clogged drain hose you need to take out the back cover in the freezer and with a turkey baster and out water you will need to defrost the drin hose
Posted on Apr 09, 2011
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
Freezer works ice maker leaks water into freezer compartment. Refridgerator cranked up all the way cold and throws warm air not cooling food it is 5 years old
sounds like its set to high on the cold selection, and it needs to actually defrost , setting the freezer to colder much of the time will worsen the problem, if you can unplug it for a day and let the machine defrost ( deice) then it will be able to actually function better, Ice causes the functions to not be able to work properly. the ice maker leak could be caused by the limit switch being frozen , remove the tray and make sure that the unit isn't clogged with ice, if it is,, leave the tray out while you have it unplugged, and it too will fix itself once the ice is removed
Jul 20, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Water leaking from freezer compartment
try finding out where the condensate from the auto defrost is going,is there a drip tray (rear bottom)thats full and (naughty)have you been loading freezer with warm food.....
May 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Model 106-74269401 mfg date 6/05. Constant pool of water on interior top shelf leaking from freezer above. What is standard repair?
That is most likely the defrost condensate pan inside the freezer has frozen over and closed the drain opening. Once that happens then the water has no where to go but the freezer or the fresh food compartment. Below is a link to different ways of this happening. Just choose the section that resembles your refrigerators problem. The water freezing over does not always need to go to the extreme measure to prevent it. It's possibly something blocking the line between the freezer and the pan under the refrigerator. Let me know what you find, Thanks, Sea Breeze
click on link
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 19, 2009 | Kenmore Refrigerators
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
