Question about Frigidaire ATF6000ES Front Load Washer
My washer won't drain or spin. I took off the back panel looking for the coin catcher pan? but see nothing obvious. There is no error code or anything that looks obvious. Any ideas?
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor. The bit about checking the motor is near the end ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 09, 2011
Will not spin or drains shows F21
The F21 error on a Whirlpool Duet washer means the unit was draining slowly. This can be caused by a blocked outlet hose (kinked hose, for example), excessive suds from using non-HE detergent or too much detergent, blockages in the drain pump filter (coin catcher), or a problem with the pump.
You should be able to clear the error by pressing Pause/Cancel twice. Check your outlet hose. Then unplug the washer. Have a bucket handy to catch the water when you access the pump. Remove the toe panel from the bottom of the washer. There are three screws to remove; then you need to lift the panel slightly and pull it forward.Check the filter for foreign objects.
Test the washer by selecting a cycle and running it with no clothing or detergent. If the unit still fails, then the pump, pump motor or the pressure switch is bad. However, you should also check the wiring to the unit.
I hope this helps. Please add a comment with the model of your washer for specific directions and parts information.
Dec 22, 2014 | Whirlpool duet Washing Machines
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FTF2140FS Front Load Washer /...
My washer won't spin. There is a coin stuck inside
If the coin is in between the 2 drums but is free floating you amy be able to get it by removing th bottom drain hose from the drum but this can become a pain unless you are lucky as the coin will move with the machine tipped over. the other way is to remove the heating element while the machine is upright and use a stick or a grabber to get it out.
Dec 30, 2012 | Washing Machines
My code is E21 how do i fix this without paying for a service call. My warrenty ran out 3 weeks ago imagine that
E21 indicates a drain pump error or slow draining. If it is a clogged filter, you fix this yourself. (Standing water is usually still in the washer with this error.) Unfortunately, if it is something else, a service call may be needed.
Unplug the washer before starting the following procedure.
The first step is to check if your washer has a lower access panel. If it does, then remove the panel. Find the drain motor and the two hoses (drain and washer sump) that connect to it. Have a bucket ready to catch the water from the hoses. Since the hoses are connected by hose clamps you will need a set of pliers to loosen. Remove the hoses and let the water in them drain out. Check for any clogs and check the coin catcher filter (it's inside the main hose) for foreign objects. Remove the blockages. Then check for around and inside the pump (and the impellers) for any object and remove anything that doesn't belong.
If your washer doesn't have an access panel, you can get to the drain motor from the back, bottom or front of the washer. Pull off the panel (usually screws hold it in place) if you are accessing the unit from the front or back. If you go from the bottom, remove the storage drawer and pedestal if you have installed those. Then remove the bolts that hold the drain motor to the washer frame. Remove the wiring harness and the drain and sump hoses. The pump can then be removed and cleaned. Follow the directions above to check for clogs or foreign objects.
Then reassemble the washer (pump, drain motor, hoses, wiring). Replace the panel. Plug the unit back in and see if the unit will drain without the error. (Just try the drain/spin cycle and see if the unit spins rapidly. There is not reason to do a full wash.)
If you add a comment with your Frigidaire washer model number, I'll be glad to give more specific information for additional repair options.
Aug 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain, burning smell on rinse cycle. appears to be spinning just not draining
Check the 'coin-catcher'. It's a small compartment in front of the pump. It's supposed to catch all the big stuff (coins, nails, screws, etc) before it damages the pump. Sometimes lint and other items will snag in the coin-catcher and clog it up... Once it clogs, it will not allow enough water to go thru to drain the machine. I would not use the machine until I got it fixed (or looked at by a repairman)... the smell you're getting could be the pump not getting enough water thru and burning itself up....
Apr 12, 2011 | Washing Machines
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer wont spin
either a bad motor control board or your coin catcher is full of stuff. i would check the coin catcher first. open the front panel and you can see the pump the coin catcher is the part that comes from the bottom of the tub to the pump.Careful when you take it out there will be water in it and you will have to be ready with a towel or shop vac. put it into drain first before taking apart. it will not drain all of the water.
Oct 31, 2008 | Washing Machines
Duet sport with an error code
I have a Whirlpool Duet and the washed load would stop and give me a F-21 error. I tipped the washer back a little and removed the three screws on the front bottom cover. There is a large white drain value, turn and open the drain (make sure you have a pan or something to catch the water and any junk inside) to remove the water. Attached to the drain is a black hose with an expanded section, squeeze this to find any loose socks, under clothes etc. I acually found three socks, a battery, a pair of tweezers and a few coins. This F-21 error is a drainage problem, don't call the repair center and pay for a serviceman, it is easy to fix yourself. I hope this helps!!
Dec 08, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
