Question about Garden
I need to adjust the drive belt tighter. How do I do that? This is for a craftsman 917.377061 lawnmower
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
wadembly
  • 462 Answers
SOURCE: riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Posted on Jun 28, 2009
AUTODOC01
  • 216 Answers
SOURCE: craftsman front wheel geer driven lawnmower, the
these are pretty simple drive belt goes to the transmission and that turns the driveshaft there are plastic cogs inside the tires that sometimes wear out and even seen a sheer pin broken take off the cover and look at the belt at the trans, spin the pully see if the shaft turns ? if it does then the wheels are the problem if it dosnt then the trans gear stripped easy fix even for layman let me know if this helps p.s. you can also go to searsparts,com for exploded veiw of driveline just type in your model # good luck
Posted on Aug 27, 2009
  • 404 Answers
SOURCE: Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Posted on Jun 02, 2010
suzukiracing
  • 200 Answers
SOURCE: How do you replace drive belt on a hydrostatic
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Posted on Jul 19, 2010
Belts on my 50 " cut 26 hp craftsman riding lawnmower model 917273320
they have 2 belts . one for deck and one for the tractor drive
Jun 27, 2017 | Craftsman Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
We have craftsman lawnmower model944605120 can't get the belt back on help
Which belt are you referring to, the PTO (Mower Deck) or the Drive Belt (to the transmission).
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jun 02, 2010 | Garden
My son has a 3 year old Craftsman lawnmower with a B&S 6.5HP engine. The engine sounds like it is running slow. It starts real easy and runs smooth but seems to be running slow. Looks like there's no...
There is a governor adjustment on it.Find the governor spring coming from the carburetor the link will lead to a governor spring hooked to a metal tab,by bending the metal tab it will pull the spring tighter making the engine run at a higher rpm
Aug 17, 2009 | Craftsman Garden
Craftsman front wheel self-propelled, push mower: belt keeps slipping off tension pin. Also, the wheels don't rotate as rapidly as when I first bought it last year.
Make sure the pulleys are aligned perfectly straight and replace the old belt with a new one. The pulleys have an allan head set screw you need to loosen to adjust the pulley.
May 03, 2009 | Garden
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
