Question about Zonet Computers & Internet
I am trying to connect a HP wireless printer & its asking me for my network name & password & I do not know it
  • 4,340 Answers
This password is the same as your wireless router access password. You need to follow the HP setup exactly, which means hooking the printer up USB during configuration. AS WELL, you will need to run the full install on EACH machine, then each one can run stuff, like a scanner, as if they hosted the printer...
Get into the router and find your wireless access code and you should be able to get things working. HP is fussy about NOT using plug and play.
Posted on Apr 09, 2011
How can i setup HP Officejet 6830 to print with USB and wireless?
There is a solution for install the hp office jet pro 6380 with USB cable connection and wireless connection on your PC.
Follow the below steps:
Configure device:
• In your printer to select Network setup.
• Then select wireless settings.
• Check the wireless is on.
• Next to choose your network name as SID.
• Now you have to enter the wireless password.
Install wireless device:
• First, download the latest Mac OS X 10.10 driver for your printer.
• Run network install.
• Now you have to test wireless printing to confirm that functioning.
Install USB device:
• First, plug USB cable on your printer to the PC.
• Click the apple menu to select the system preferences.
• Select the print & scan option to check your printer name.
• Now click plus sign to select the add printer or scanner.
• Ensure that hp Officejet driver is selected.
If you still have any doubt or issues you can also contact our customer support to help you regarding your HP printer issue @ +1-800-836-3987 or visit 123.hp.com 6830 oj.
Jul 21, 2017 | HP Office Equipment & Supplies
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
I cant find ssid while installing hp deskjet 3050, how can i find wireless network name?
download and run network diagnostic utility from the hp website. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&jumpid=ex_r4155/hho/ipg/ccdoc/network_diag/&lang=en&softwareitem=mp-96434-1
  • click on the start button
  • select not listed.Information will be provided to help the user get the printer connected to their network. For a wireless connection, the network diagnostic may also help get wireless settings such as the network name (SSID) and security key (WEP/WPA).
or
go to control panel,network connections,right-click icon for wireless connection,click properties,then look for view available wireless connections.
Jul 23, 2011 | HP LaserJet 3050 Printer
I have a Arris TM722 modem and I need to know my SSID number and password? please help me!
An SSID is the name of your wireless network connection and doesn't have to be a number. As I don't believe that this modem supports wireless connectivity, it should not prompt you for an SSID or a password. If the modem is plugged into a wireless router however, and a wireless network has been set up, the SSID will be related to the wireless router.
Generally most devices can scan for the SSID when attempting to connect to a wireless connection. If there is an "automatic" setting or a "find networks" button, you can try that and choose your wireless connection from the list provided. For a password, you may need to ask whomever helped set up your wireless network.
Jun 01, 2011 | Office Equipment & Supplies
I have a new Belkin Play router and when I watch a video online (like a you tube video) it pops up and says that my Belkin router password may have changed. It then asks me to re-enter my password and then...
= The Belkin Router Utility Might Not have Been Installed Properly.
> To Get Rid of this Issue 1st of all Disable or Uninstall Belkin Router Utility.
- Goto Start > Control Panel > Uninstall Programs
- Select Belkin Router Manager Utility & Uninstall It.
> Now you Have to Remove preferred Networks & Join the wireless Network.
Steps to Remove Preferred Network & Joining the Network
- Windows XP
- Goto Start > Control Panel > Network Connections > Right Click on Wireless Network Connection > Click on Properties > Select Wireless Networks Tab > Under Preferred Networks Box > Select your Wireless Network Name & Click on Remove Button. Close the window
- Right Click on Wireless Network Connection & Click on View Available wireless Networks.
- Wireless Network Connection window will appear. Select the network you wish to connect and click Connect. It will ask you For a Network Key Type in your Password.
> Windows Vista & Windows 7
- Go to Control Panel > Network and Sharing Center > Click on Manage wireless networks Right click on your wireless Network > Click on Remove Network .
> Connecting to a Wireless Network.
- Goto Network & Sharing Center Click Connect to
- Select your wireless network & click Connect
- It will ask you For a Security Key Type in your Password.
( If you are unable to go online you can try power cycling the router for about 15 seconds. If Even Power cycling doesn't work that means you have to disable WPS option on the Belkin router)
Mar 08, 2011 | Belkin Computers & Internet
Trying to connect to wireless network.says i am connected and signal strength is excellent but still wont connect.what am i doing wrong as i am a novice with laptops
if u r using vista or windows 7 then type 'network & sharing centre' in the search bar which u get after clicking on the 'start' button on the bottom left hand side corner-->go to the 'network & sharing center'-->click on 'manage wireless networks' on the right hand side column-->u will c the name of one or more than one networks listed over there-->remove all the networks-->u will get the option to remove by clicking on the network name-->after removing all the networks, close the page-->again click on 'start' option & click on the 'connect to' option on the right hand side column-->ur notebook will detect all the network signals & will show the name of all the networks present at ur place-->select the network to which u want to connect & click on the 'connect' option-->it might ask for a password only if the network is password protected-->enter the password & u will go online....
try this, there are chances that it might resolve ur issue & if it does then let me know by rating this solution.....
Jul 08, 2010 | HP 510 Notebook
I dont know how to setup a wireless printer to my laptop. I have a wireless router and an ethernet cable plugged in, but how do I set it on my computer wirelessly?
Well what you do is, First, install the correct driver for your Printer on the one chosen to be the, "Master" PC, then, connect the Printer to that PC via the USB cable. Then after it is installed & shows up,Go to the setup & in the printers Properties, ensure you set the printer for "Sharing" & Take note of where it "Is" & it's "Name" & "Path". Also ALL your PC's MUST have an INDIVIDUAL NAME and be connected to the SAME "Workgroup". Then from each "Client" you must Install a Printer too. Now on Client, go to, Install a Printer, & run it, when it asks what sort? You identify "Networked Printer" and "Browse" for it. When you find it, simply connect to it and follow any instructions. If you can't find it, enter the name of master pc & printers name... (from the Master install). When you connect follow any instructions Now you are ready to print..
When you look for the printer it will look like this....\\Nameofyourpc\PrinterNamehere
So basically, you have setup a network, with the PC's & a Printer... You have one Master that the Printer is connected to, & all "Others" connect, to the Printer, Through, the Master PC, subsequently it must be ON for it all to function.
There is another way, and that requires a printer with an Ethernet connector, this then, can be simply plugged into a router port & it will show up as a network share, that can be used by anyone else on the network., As such there is no master and no need to have any other PC's powered up for it all to work.
Feb 02, 2010 | HP PSC 1410v All-in-One Printer
We have a hp c4580 wireless printer and we are having problems with getting it to work. Can you please advice what to do. Bethany
Basically, you need to configure the HP C4580 printer with the same wireless settings of your network. Thus, you need to get the following information from your wireless router:
SSID or wireless network name
Type of Wireless Security
Wireless Security key/passphrase/password
To set those settings on the printer itself, you need to temporarily connect first your printer to the computer through USB. Then run the HP Printer Setup CD. It'll ask for you to install the required software then it'll ask for you to configure the printer on a wireless network. From then on, you will need to input the wireless settings that you got from your router.
Oct 12, 2009 | HP Photosmart C4580 All-in-One InkJet...
Whereless conection
This printer does not have wireless built in. Are you trying to access it across a network? If so just add the printer and type in its location on the network. Also what operating system are you using. I will need a lot more information to give you a complete answer.
Thanks,
Lee
Aug 08, 2009 | Lexmark X2600 InkJet Printer
Problem connecting laptop to wireless router
Leave all fields blank except password, the password is "admin".
Apr 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Computers & Internet Logo
172 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
