Question about EliteGroup G320 Notebook
My laptop won't power on (EliteGroup G320 PC Notebook)
With the DC adaptor plugged in, and the green "plugged in" indicator lit, I press the power on button. The "plugged in" indicator light goes off, and nothing else happens. If I unplug the adaptor and plug it back in, the green light goes on again, but it still won't power on. No lights and nothing will power up with just the battery, either. I have a spare battery and have switched batteries and the same thing (doesn't) happen.
For the record, several months ago I had a loose DC jack which was replaced. Everything worked okay yesterday, but nothing works today.
Is my laptop dead, or could it possibly be some bad contacts with the switches, caused by dust or something?
  • 1 more comment
  • GeorgeBakos Feb 02, 2009
    I have the same problem. For the very beginning with the DC adaptor plugged in, the green "plugged in" indicator lit, when I pressed the power on button the "plugged in" indicator light goes off, and nothing else happened. Ten fifteen times happened the same thing but now if I unplug the adaptor and plug it back in, the green light goes not on and it still won't power on. I went to a repair shop and the gentlemen told me that the best solution to buy a new laptop and try to use the old hard drive as this particular problem is hard to solve, cost lot of money and the laptop is nothing worth. If somebody have solution on this problem please send a note to BellaVita_palmdesert@yahoo.com. Thanks for your help with this matter. George
  • GeorgeBakos Feb 03, 2009
    I face the same problem. With the DC adaptor plugged in, and the green "plugged in" indicator lit. When I press the power on button the "plugged in" indicator light goes off, and nothing else happens. If I unplug the adaptor and plug it back in, the green light goes on again, but it still won't power on. I tried several times to power on the computer but after the tenth or fifteenth time it gave up and now the indicator light goes not on and my computer is useless.
    I went to a repair shop and the gentlemen advised me to buy a new computer as the G320 is nothing worth and useless to spend money on it.
    Can somebody help me to solve this problem?
  • Anonymous Feb 07, 2009
    Hello LaptopLady.
    My dauchter (13 years) has the same laptop G320, and execly the same problem, and I am looking all over the web to find a solucion...no luck till now, please let me know when you find a solucion, I come back to you if I find a solucion.
    solarpower@sopodi.com here is where you can contact mi :)
  • 3 Answers
Sounds like the infamous electrolytic capacitor plague (see http://en.wikipedia.org/wiki/Capacitor_plague -- also read the discussion page)
In the early years of this century chinese spys stole a formula for novel electrolyte from a leading Japanese chemical company but unfortunately they only copied page 1 of the two-page recipe. The incomplete electrolyte went into many millions of capacitors reducing their life span dramatically. I understand these capacitors were made until 2004. That's about the time the G320 was manufactured, at least mine.
I opened and disassembled everything, I saw some "swollen" 1500uF/6.3V capacitors, replaced them and the G320 would start again.
This may sound easier than it was, however. I live in a country where computers aren't made no more and spare parts are hard to find. The G320 has 4 of the above caps in upright position and 4 placed horizontally. I could only get some larger types that do fit horizontally but not vertically. Thus I had to replace a bad vertical one by one of the remaining good horizontal ones and then replace the horizontal ones by the bigger ones.
Warning!
If you re-assemble your G320 make sure you use the shortest 3 screws for the the points where the upper cover is fastened to the metal sheet frame that presses the cpu against the heat sink. If you use a longer screw (which I did) you may experience that a destroyed 4x56 ohms resistor network chip on the mainboard can also be hard to be relaced in non computer producing countries.
Mittwoch
Posted on Nov 14, 2009
  • mittwoch Jan 23, 2010
    Meanwhile I've repaired a couple of Elitegroup/ECS G320 Laptops that wouldn't power up. It's the capacitors, believe me!
1) Remove the Battery 2) Heats the zone of power jack with one hair dryer (Phon) 3) Test to start (push the start Button) 4) If it works there it is a problem of cold welding 5) Try to repairs (welding) or it sends in attendance
Posted on May 15, 2009
    Problem Solver:
  • 6 Answers
I had the same problems. What I did initially was soldered a lead wire to pin 1 of the AMS1505CMA regulator and another wire to one leg of the 1500uF/16V capacitor that is close the AMS1505CMA IC. I short these two wires and the laptop turns on. Eventually after a few weeks it won't turn on anymore. I replaced the AMS1505CMA and now it is working fine.
Posted on May 21, 2010
  • Irwin Zosa May 21, 2010
    Sorry, it is not pin 1 of the AMS1505CMA but rather pin 3.
  • Irwin Zosa May 22, 2010
    A clearer explanation: I soldered a lead wire to pin 3 of the AMS1505CMA regulator and another to the positive leg of one of the two 1500uF/6.3V capacitors located close to the regulator. This leg of the capacitor supplies about 3.3 VDC. I then momentarily short the two leads together and the laptop will turn on. Eventually I replaced the AMS1505CMA with a new one that I ordered from a supplier in China as I cannot source this exact part from anywhere else. Do make sure that you get the exact AMS1505CMA in the TO-263 package since this part has many variations (different output voltages). While you are doing the replacement of the regulator, might as well replace the four 1500uF/6.3v electrolytic capacitors with new ones (105 degrees C, low ESR types)
SEND YOUR LAPTOPS TO MY ADRESS: ROMANIA , SIBIU, STR. BIHORULUI BL. 2 AP 12 550064 TRUFIN ALEX.
Posted on Apr 10, 2009
I have a G320 laptop with 512 SO-DIMM DDR400 and 1 GhZ procesor ,OS WIN XP, how can I run my G320 faster
There is nothing much that can be done to speed up the system as it can not go beyond 1GHz Processing speed, but several operating system tweaks and some hardware upgrade could make a little but notable difference.
As for Hardware, you may increase the RAM. You can upgrade memory on ECS Elitegroup Computer G320 upto a maximum of 1.0 GB (The ECS Elitegroup Computer G320 takes the PC2100 DDR SDRAM SODIMMs Memory)
Secondly, You may increase the size of PAGE FILE, uninstall unwanted software, Remove unwanted start-up items, Clean Junk Files/ Temporary files, De-fragment the Hard Disk to achieve the maximum speed and performance that EliteGroup G320 PC can give.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | EliteGroup G320 Notebook
No power. no lights. I have checked the power cord and its like there is no power
Firstly check that there is power to the Ac adaptor, this can be done by seeing if the green power indicator light is on on the adaptor body.
If not, then you have a defective plug, blown 3 amp fuse or the adaptor is fried (not uncommon)
If you have a multimeter, you can set it to 20 volts DC and with the adaptor pligged into the mains, test the DC JACK end! by putting the red probe to the inner part of the jack and the black to the outer part, if no reading, then assume the adaptor is dead.
Best way to check is by testing with an adaptor (universal charger type) to see if that works.
Assuming the adaptor is putting out power, check the output with a multimeter as above and see if the voltage is at the correct level (think its 19 volts on that model). If it is, then move on to the DC jack connection on the netbook
Watch the power indicator on the adaptor, if it is not steady green (ie flashes on and off), ther power is not making a circuit in the alptop and is being "spat back", this can be anything from a blown circuit board in the power circuit, to something as simple as a motherboard main fuse.
If there is a staedy green light but no power at the netbook and the jack connection at the netbook is firm and not sloppy or loose, then you will need to have the netbook dismantled and the fuse checked ( this will also need to happen if the jack connection is loose.
Sometimes, removing the battery, pressing the power button on (with the adapator unplugged) for 30 seconds and repowering with the ac adaptor can reboot the system, but I'd be inclined to suspect the adaptor first
Apr 22, 2011 | Acer Aspire One PC Notebook
My elitegroup laptop was no power at all, then the pin positive is shorted to pin negative
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | EliteGroup G320 Notebook
What key or keys gets you into the elitegroup G320 bios. Thanks
The usual "suspects":
* DEL
* Enter
* F1
* F2
* F10
* F12
* ESC
Try them all.
May 12, 2010 | PC Chips G320 Notebook
WHAT KEY OR KEYS GETS YOU INTO THE ELITEGROUP G320 BIOS. THANKS
Most laptops either use the [F2] or [Del] key to access the BIOS. If not, it could be either [Esc], [F1] or [F12]. You might also try [Ctrl]+Key, [Alt]+Key or [Shift]+Key combinations if the previous keys don't work.
Make sure you don't get past the initial POST screen when trying the keys.
Mar 21, 2010 | EliteGroup G320 Notebook
How enter ECS elitegroup G320 laptop bios
I have ECS A900 and to enter BIOS, you press DEL key.
I found that the hard way :)
Oct 31, 2009 | EliteGroup G320 Notebook
Elitegroup/ECS Laptop G320 - it's dead mom :-(
It's because of faulty capacitors. Look here:
http://www.fixya.com/support/t890498-laptop_power_elitegroup_g320_pc_notebook
Oct 07, 2009 | EliteGroup G320 Notebook
DC Adapter for laptop doesn't work
there is nothing you can do appart from replace the car adaptor or check that the cigarette lighter is recieving power to the socket
regards
Nov 24, 2008 | Dell Inspiron 6000 Notebook
On button
Look at the power indicator. If it is not lit, no power is being supplied to the computer. Check the following:
  1. If you are using on the battery, it may be low and unable to power the computer. Connect the AC adaptor to recharge the battery pack.
  2. Make sure that the AC adaptor is properly plugged into the computer and to the power outlet.
If it is lit, check the following:
  1. Is a non-bootable (non-system) disk in the external USB floppy drive?
  2. Remove or replace it with a system disk and press <Ctrl> + <Alt> +<Del> to restart the system.
The computer's power management system automatically blanks the screen to save power. Press any key to turn the display back on. If pressing a key does not turn the display back on, three things might be the cause:
  1. The brightness level might be too low. Press <Fn> + <→> (increase) to adjust the brightness level.
  2. The display device might be set to an external monitor. Press the display toggle hot key <Fn> + <F5> to toggle the display back to the computer.
  3. If the Sleep indicator is lit, the computer is in Sleep mode. Press and release the power button to resume.
Dec 17, 2007 | Acer Aspire 3000 Notebook
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
EliteGroup G320 Notebook Logo
1,781 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
