Question about Vehicle Parts & Accessories
I have a gemel car alarm security install in an hrv car but l mistakingly lock or press the alarm inside the car, which trigger blaring of alarm; press the alarm again to unlock but car will not start nor engine is not running or petrol cut off. What can l do to start the car
  • 13 Answers
SOURCE: Avital 2200 Car Alarm caused BCM Malfunction
Yes it is true that dealerships will always blame aftermarket installments and installers hands down. That being because they can try to void your warrenty that way. Now is it possible the system triggered your BCM? yes it has happened in the past but if they were an Authorized dealer they would have the information telling them how to avoid that problem. Now I would say this if the dealer cost you $598 for a new BCM first make sure you got the old BCM from the dealership. Then I would take the old one to the Authorized dealer and have them shell out the $598 because they were the ones that had the BCM fail not you and also that is what they pay for insurence. There insurence will cover their mistake. hope that helped.
Luis
Posted on Dec 04, 2008
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
insanegtp
  • 112 Answers
SOURCE: i cant cut off my alarm and car wont start
is ti and aftermarket or factory system, if aftermarket look for little black button under dash or button on antenna, turn key on and press for one full second, if aftermarket unlock door with either trunk or passenger side and try again...
Posted on Jan 26, 2009
  • 47 Answers
SOURCE: Disable or disconnect the factory installed alarm
should be a fuse for it, just remove it......
Posted on Jul 07, 2009
  • 1596 Answers
SOURCE: car alarm siren won't work but still can locked and unlocked the
REPLACE SIRIEN
Posted on Jul 12, 2009
2000 sebring JXI car alarm won't shut off. Soon as I connect the battery it starts blaring, continues while the car is running. Only way to shut off is disconnect the battery. What can I do??
Try connecting the battery, while alarm is blaring, lock the door with the button on the inside of the door, shut the door, unlock with the key, then start. It worked on a friends durango.
Feb 08, 2017 | 2000 Chrysler Sebring JXi
2005 camry need to know
Have you tried locking all the doors windows up then using the door key not the key fob if you have one. Put the key in And manually unlocking the door this usually resets and disarms the security system in most modern vehicles. The alarm and security system will continue to function properly but this a a manual override to shut down the security systems sensors and make the audible alarm system to reset and stop sounding the ala
Apr 10, 2014 | Vehicle Parts & Accessories
I am getting a second alarm when the first lock alarm is pressed in my wingroad car and when you open the doors the alarm is not coming on
If you open the doors when the alarm is armed and, the alarm does not trigger then, you have the wrong door trigger wire connected. If you were to list the year, make and model of the vehicle I could direct you to the proper wire and location.
Jun 28, 2013 | 5601 1Way SuperCode Security and Remote...
I have had a flat battery in my Toyota Camry and I have had to break into the car to pop the bonnet and charge the battery. The battery seems fine but whenever I put the key in the ignition, the security...
Seems you have activated your alarm.Try closing the door and locking it with your key and then unlock it ,it should reset.
don,t forget to rate..
Sep 25, 2010 | 2008 Toyota Camry
I have a Gemel Serpi Star alarm gr40 fitted to a 1991 bmw E36, I need to find a wiring diagram, can anyone help. Thank you
Im trying to fit an E90 siren to my E36. Were you every able to get the siren working? please email me at weber.ryan1@gmail.com either way
Apr 21, 2010 | Anti-theft Alarm System 3 Series E90 E92...
Bought a 98 Nissan Maxima 3 days ago...first car for our 16 year old. Service engine light came on auto parts store hooked up to computer and told us it needed two 02 sensor & knock sensor. The next...
Connect battery>>>>try unlocking the vehicle from the inside (door closed), using the power un/lock button. Make sure the key is set to the "on" position. Most of the time this works. If this doesnt work, try using the key to lock and unlock the door through the key hole. Hopefully this helps!!
Apr 15, 2010 | 1998 Nissan Maxima
Luis
Nov 25, 2008 | 822001/2200 2200 SECURITY SYSTEM
Door keeps unlocking and alarm keeps coming on
it sounds like it is in the door lock actuator and the security mode itself now if you have a remote starter installed you may have to take it back to the person who installed it because the problem maybe in your security system
Oct 30, 2008 | 2006 Ford Taurus
My security system continues to sound when you open up the locked door.
I have a 1992 Acura Legend. If the alarm goes off when you open the door when the alarm is set you may have to close the door and put the key in the door lock and turn it clockwise to turn the alarm off.
Jul 25, 2008 | 1992 Acura Legend
RCA RP3750 - set up for No alarms at all?
1. Press "Off"
2. Press "Cancel" then press "WK1"
3. Press "Cancel" then press "WK2"
Dec 04, 2007 | RCA RP3750 Clock Radio
Vehicle Parts & Accessories Logo
156 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
