Question about Health & Beauty
Have a BV250 Piaggio. Battery is dead. how do I lift the seat to get at it?
  • 5,370 Answers
Under the seat, behind the storage compartment, there's a gray piece of plastic that covers the battery. You've got to take a couple of screws out to get to it, but it's under there. It's right in front of your top box and rear rack. ------- You have to remove the panel that surrounds the latch for the seat and the panel that contains your brake light to gain access the battery and the main fuse block. ---------- I'm pointing right at it, and the two screws on either side of the latch are removed to take the cover off. It kind of hooks on the back side, so you've got to slide it rearward to remove it. Click this link to view the picture:--- http://postimage.org/image/2ewy35nwk/ --------------- Once that screws are removed, lift the latch and you will see the battery.:--- That black is battery and beside, there is a vent tube.Remove the battery without disturbing then vent tube. Have a BV250 Piaggio. Battery - helpmech_109.jpg
-------- There is also a service manual for your vehicle.Click this link to get service manual:--- http://www.scribd.com/doc/32353759/Piaggio-BV250-Workshop-Manual-USA ------------------ This should help.Thanks.Helpmech.
Posted on Apr 09, 2011
My piaggio MP3 3 wheeled scooter won't start after I stopped it thinking starter fuse
Is the battery dead, they do just go open circuit with not warning, very common in compact batteries. Check the voltage at the battery.
Sep 08, 2016 | Piaggio Motorcycles
HOW DO I TAKE THE HEAD ASSEMBLY OFF IN ORDER TO CHANGE A LAMP ON A BV250 PIAGGIO 2007 SCOOTER
Hi, Tony for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Piaggio, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Modern Vespa Need help changing head lights on 2006 Piaggio BV 250
Piaggio Beverly 250 USA Workshop Manual
Piaggio Fly Headlight Handlebar Cover Removal
PIAGGIO Beverly 250 User Manual
May 15, 2016 | 2011 Piaggio Liberty 50
How do I use a battery charger with a Piaggio 50 Scooter
A small(2amp or less) charger red lead to + black lead to - for 3 to 5 hours should do it . Not sure of your battery location however a scooter is typically under the seat or in a box with removable lid under the floormat.
Dec 14, 2014 | 2010 Piaggio Zip 50
How do I remove the battery from a piaggio fly 2012
Should be under the seat behind a battery cover. You'll need basic tools.
Oct 12, 2014 | 2011 Piaggio Fly 50
Piaggio bv250 tourer
one of them scooter thingys ,i do think i would i would need a good look here to be honest ,have had some sucess with a helper who works the manual release and i attack the seat with a big screwdriver ,but this is brutish to say the least and it does work sometimes if the catch is just short of a good lube up with the oil can but sometimes they get bent where the locking bar is and the only alternative is to a good wrench and break it all off ,best advice here is go to the main agant and get them to have a look ,it may be cheaper than breakinmg anything
Nov 01, 2013 | Renault Cars & Trucks
Piaggio zip 125 electrical
Hi, Bilywalker before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
Scooter Troubleshooting Scooter won start All about Scooters
Piaggio Fly 150 4T Workshop Manual
https://www.oemmotorparts.com/oem2.asp?M=piaggio
PIAGGIO MP3 125 User Manual
May 28, 2017 | Piaggio Motorcycles
How can I start the Piaggio XEvo 250 Scooter as I've fogoten to clost the back cover which caused battery running out. And I can not open the seat to start the scooter by using car battery. Thanks
Hi You first open the refuel cap cover There is the cable wich opens the rear cargo compartment From there you reach th seat latch an manualy release him There you are !!!
Sep 27, 2011 | 2008 Piaggio XEvo 250
I have a 09 Piaggio Fly 50. When I bought it, the battery was run down from lack of use and extreme cold (I used to live in the Rockies). I could never start it from the starter button, but always with a...
Hi, Jkranowitz before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
10. Starter relay, solenoid or starter circuit wiring faulty.
My Piaggio 50 Won start
How to Troubleshoot Your Piaggio
PIAGGIO MSS Fly 50 4T Workshop Manual
2009 Piaggio Fly 50
http://motorscooterguide.net/Piaggio/Fly_Series/Fly-50-and-150.html
Apr 12, 2017 | 2011 Piaggio Fly 50
Piaggio mp3 400 unable to manualy lift seat. to gain access to battery compartment.
There is a compartment under the saddle see picture 03 18 below. You need to use the key fob to open the saddle. The manual says open the fixings A and remove the cover B. what type of fixings are not stated.
Jan 27, 2011 | Factory bike Chrono SM 250 Motorcycles
Battery location
The battery for the Marauder is located under the seat. Check behind the passenger peg on the right side (the side the exhaust pipes are on) , there should be a lock. Use the bikes key to unlock the seat. You should be able to lift the seat from the back and pull it backwards as you lift it. You should see your battery. Hope this helps.
Mar 18, 2009 | 2000 Suzuki VZ 800 Marauder
Health & Beauty Logo
436 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
