Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a bleue letter "K" on my sharp LCD aquos. i cannot have any cannal and i just can add volume by 30-60.please what can i do ? help me!!!!!!!!!!!!!!!!!!!!!!
SOURCE: Sharp Aquos
Background:
This "K" message is actually a factory service mode used for bench testing. You might have accidentally gotten into it somehow.
How to fix it:
The only way to get out of it is a series of button presses, known only to Sharp (1800 237 4277) and service centers. Though the latter will charge you to clear the message. Call Sharp and ask to speak with their 'dispatch group' to get around this.
Posted on Mar 19, 2008
SOURCE: yellow box with the letter "K" in it.
Most likely the LC sound control is blown and must be replaced.
Posted on Sep 17, 2007
  • 53 Answers
the TV needs to be reset with the Factory Initialization. Try contacting Sharp at 1-800-327-4277 for instructions.
Posted on Mar 14, 2008
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
chrispurs1
  • 372 Answers
SOURCE: SHARP AQUOS 32 INCH FLAT SCREEN
Hi.
Easy fix do the following.
Set is in factory mode. To remove follow these steps below extracted from the service manual.
  1. Unplug the AC power cord of TV set to force power off.
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. The letter K should have disappeared from the screen.
http://dysonmanuals.llc.nu/
Posted on Mar 30, 2008
Need user manual for 42"sharp aquos lcd tv
Hi Rebecca,
Please click this LINK to download the Pdf file format of Sharp LC-42D65U User Manual.
Click "Download Document", enter your email add, enter the confirmation no., and then click "Download". It is a safe website, I used it personally.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jul 09, 2011 | Sharp Televison & Video
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp aquos 32' LCD has a heavy green tint to it. I tried reseting the settings back to factory settings, but it didn't help.
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Aug 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Have Sky plus and the remote does not accept any codes I have got, so no volume control via Sky remote. Do you have the correct code for a Sharp Aquos 46" ? Thanks
please follow the steps below:
TV
RED + SELECT
TV
0093
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jul 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I had this problem as well guys. Just found a fix thought i'd share.
I simply went into menu>setup>reset . This will perform a factory reset, and you shouldn't have that K or the volume problem anymore.
I tried all the fixes involving volume- input- nothing worked. I tried volume- ch- but that K never changed colours.
It all came down to a simple menu option reset.
Mar 29, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume control
I am a Sharp servicing technician and I have seen this "problem" with this particular model many times. I have tried replacing the Main Board and the Terminal Board and it does not help. The reason i put "problem" in quotes is because I came to the conclusion that this is model is just not that loud. However, a few months after the initial production run, BAM, these TV's are as loud as any other TV on the market so sharp must have caught onto this.
Dec 31, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Yellow box with the letter "K" in it.
Sep 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
447 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
