My oil boiler keeps locking out - Heating & Cooling
  • 1,420 Answers
Turn off the power to the system and then open up the transformer using a 5/16 nut driver. The transformer is hinged and it will flip out of the way. Look for a small black cylinder with yellow wires. Clean off the eye. Then turn off your oil supply to the burner. Using a 7/16 wrench, unscrew the very small copper line at the end where it enters into the burner housing, then spin off the round nut holding the drawer assembly. Rotate the drawer assembly and pull it out. Inspect the nozzle for soot and replace. The size and angle of spray will be marked on the side of it. Inspect and adjust your electrodes according to the manufactures specifications of the burner (not the boiler). Put everything back together and test fire it. If your boiler has not been cleaned in the last year, change the filter at the oil tank. If it continues to lock-out, change the primary control (usually honeywell 8184G) with a newer version.
Posted on Apr 09, 2011
Baxi back boiler keeps gurgling and rumbling then knocks off any help please
Gas or oil if oil when was the last time you had service on the unit? If reasonable amount of time probably wrong nozzle you want more info need to know what type of boiler gas or oil e mail me at vschnittert@gmail.com I can probably walk you through it
Apr 02, 2015 | Heating & Cooling
Digital control keep flushing error3
boiler not getting up to temperature fast enough. If it is an electric boiler, there is a problem with the heating element. If it is oil o rgas fired, you do not have a flame or the boiler temperature is not reaching 180 degrees F.
Mar 19, 2015 | Amtrol Water Heaters
What would cause my weil mclain oil fired furnace to lock out? any help would be greatly appreciated thank yo. . Charlie
Could be the photocell (CAD cell) on a residential boiler, or a fuel problem ie dirty fuel filter, oil lines losing prime.
Mar 15, 2015 | Heating & Cooling
Hi, my firebrid 115 wouldnt start tuedsay after running out of oil, had a deliverary of oil and my oil man bled the boiler as it had a air lock, the heating was working fine the rest of the day and a
He may have bled the lines but did he also bleed the fuel filter as well. All oil tanks have an oil filter in them, sometimes two. He could hav bleed the lines but still had some residual air in the line, the filter, or somewhere else along the supplu side. I"m sure if you call and explain the situation they will come and rebleed the rest of the air out of the system,especially if you're a regular customer. Also have them check the tank fuel filter, if it's clogged that too would keep oil from getting to the burners.
Dec 04, 2014 | Water Heaters
Ran out of oil, now refilled, but boiler won't ignite. Tried all as owners manual instructs, but still keeps locking out - help please
After running out of fuel,you need to bleed the oil pump on your burner.There should be a 3/8 bleed port on the bottom of your burner pump. The bleeder valve looks like a nipple. A 3/8 opened end will fit over it.Put a can or cup under it,open it a bit and reset your control.when pure oil comes out close it and burner will fire.If your not good with it you should get a tech or handy man to do it.
Nov 27, 2010 | Heating & Cooling
Domestic oil fired central heating. Keeps tripping out with no oil feed(has tiger loop and this is empty) If oil is drawn through filling tiger loop again boiler will fire up and run for betweeen 2 days...
many times the feeder tube from the bottom of the tank becomes perforated. the return tube is ok most of the time . try switching the 3 8 tubes from inlet to outlet and see if problem resolved. if so the the tube down into the tank is flawed.
Oct 31, 2008 | Heating & Cooling
Furnace shutting off
IF THIS IS A OIL FIRED BOILER OR FURNACE IT IS NOT SEEING THE PROPER FLAME SO THIS IS A SAFETY CALL FURNACE TECH
Oct 30, 2008 | Electrical Supplies
Riello oil burner RDB with red plastic cover at the front wont ignite. I've tried bleeding the valve. The motor seems to make an electrical humming noise for about 12 secs, then the system attempts to...
The motor should spin when the boiler is switched on. One end of the motor spins the fan the other end works the pump. The control box then starts the transformer that starts a spark. The control box then opens up the oil. The boiler should then light if any of the above or the boiler does not light, the boiler will go to lockout.
From what you say the motor is not spinning, thus it could be the motor or more like the pump.
YOU SHOULD NOT PLAY WITHE THE PUMP
If the wrong setting is made it could 1 burn out the back of your boiler 2 go to soot and the boilers in an hour would be filled up and become a fire risk. 3 not start at all if the setting is too low it is a fine line to get it to work and needs the right tools.
regards
oil eng.
Oct 26, 2008 | Heating & Cooling
Heating & Cooling Logo
400 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
