Question about Danby 17 in. DDW1802W Designer Series Built-in Dishwasher
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
Dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Posted on Nov 04, 2011
Dishwasher repair. Problem: water in bottom of machine, not draining/ cannot select any mode other than 'Auto'/ usually does not start. What happens when I try to run it: Switch on. On switch lights
I had a similar issue. I took off the drain hose, ran hot water thru it and removed the hose going into the garbage disposal there was some built
build up on the inside, cleanness it good put through houses back together and everything was fine. Hope this
Dec 23, 2014 | Dishwashers
The oven locks, it starts beeping and the panel says F5E0. How do I remedy this problem?
F5 - E0 Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door) 1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes
Nov 06, 2010 | Whirlpool RF365 Electric Kitchen Range
Microwave will not turn on -- light does not come
Chances are good that you have a bad door switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 22, 2010 | Whirlpool RMC275PD Microwave Oven
Microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
Sep 06, 2009 | Kenmore Microwave Ovens
Beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
4. Re-apply power.
May 29, 2009 | Whirlpool RBD305PR Electric Double Oven
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
My Kenmore electric dryer won't start... I just ran it and it ran fine. Went to start a new load and it wouldn't work. Checked breaker, plug and door switch; everything seems okay
eazy first.need 220 if got,door switch it wiil click when depressed.next check where cord attaches.then the thermoal fuse.if has back panel or no same info.i call them missiles or flying saucers[thats what they look like].there white small have two wires to them.if you put the two wires too gether and isolate them,if problem your dryer will start,replace,but its a thermal fuse so the idea is if it gets to hot they open to stop fires,so mcheck all venting and dryer air waysGod is good,tom
Jan 02, 2009 | Dryers
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
MDE9606AYW Maytag Dryer
the start button activates a realy inside the control panel
the relay latches to supply heavy current to motor and heater, until door switch or timer switch break the latching circuit
If relay is on its last legs, it could be causing delay in starting, not closing secondary
the relay is represented by the dashed switches at the right of this maytag wiring diagram, note that it has no relevance to physical position of components
cc57668.jpg the relay in maytags looks like this
36631dd.jpg, but may be opaque, and mounted vertically (pic left is up)
Oct 07, 2008 | Dryers
Danby 17 in. DDW1802W Designer Series Built-in Dishwasher Logo
266 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
