My ac is not even one year old and has stopped cooling
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Apr 09, 2011
Good day ! I have a Koolatron WC12 cooler that stopped cooling ,the fan works !It is not even a year old ?
1-800-265-8456 phone # for parts/service
Koolatron
U.S.A.
433 0 Commerce Dr.
Bata via, NY 14020-4102 U.S.A.
It is out of warranty if more than a year old.
I can find no service manual. There is a generic video: http://www.newair.com/kb/repair-cooling-kit-wine-cooler/
Replacement parts were sold at Truck Stops. That said, coolers are not known for their longevity. Source: http://www.truck-drivers-money-saving-tips.com/thermoelectric-cooler.html
What to Do When your Wine Cooler Wont Cool
Jun 10, 2017 | Koolatron Refrigerators
Overheating problem, what is the most probable cause?
You need to stop using it immediately before you
cause some damage or more than you may already have
That is just common sense. It should not overheat or
be any different than it was in the past without problem
The car has to be checked over/diagnosed,tested,etc for
various issues to resolve
Borrow or Rent a car until resolved
No way to guess at the problem
You should have some type of codes avail even
if the check light isn't on,you need professional help
to get a start on resolving
The timing belt maybe worn & jumped or the head gasket
bad.
Over heating isn't usually a cheap repair unless the thermostat
sticks partially closed
The RPM moves around the car is 11 years old,so it may just
need a though going over
Timing Belt,O2 Sensors,Exhaust Converter,Spark Plugs
and such
If you depend on a repair shop to do things & don't
have the knowledge to request work done throughout
the year,then you run into a lack of proactive preventative
maintenance situation. Most things are simple looking
back, once resolved
Sep 06, 2012 | 2002 Chevrolet Prizm
How to stop a leak
the water leak is not a big concern -other than the mess it causes, but as to the AC's operational status it is supposed to draw water/humidity from the 'cooling space' so - it's still doing it's job (I'm assuming it's cooling too).
As to the water - I would check the drain to be sure it's not clogged up - which is usually the problem. If the drain is clear and the AC is draining (to the outside) properly - I would then check and make sure the AC is tilted backwards out the window.
good luck!
Jul 13, 2010 | Carrier BCA101R Air Conditioner
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Refrigerators
BMW 328i AC Not Cooling
Check the temperature control box.
Jul 30, 2009 | 2003 BMW 5 Series
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
My Kenmore 75121 A/C stopped cooling air. What should I do?
It's less than a year old -- I would return it to Sears. It needs repairing & is probably under warranty.
Apr 29, 2009 | Heating & Cooling
Stopped cooling
Hello cpuklutz
Welcome
You said, Kenmore; 21 cu ft; 10-years old; just stopped cooling; wondering if it even makes any financial sense to get estimate to repair, or is 10 years about it's trouble free length of service
Here is an article that you may find useful and interesting related to your situation.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thank You, HUUUM
Please remember to enter a rating before you sign off!
Sep 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
