Compaq Presario S6500NX (DQ181A#ABA) PC Desktop Logo
Posted on Apr 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My video and audio are "skipping". It makes no difference whether I am streaming video or viewing previously down loaded videos. I have gone to the HP site and downloaded all drivers that are available for my computer and reinstalled the drivers without sucess. I have run the unboard video tool without sucess. Any suggestions?
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Apr 09, 2011
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512860
Points
14106
I have a feeling that your CPU usage might be too high and so is the memory utiliztion. When you are playing the video open task manager and check both of these then let me know.
Video delayed
Live streams are used to broadcast live video over the Internet. Whether the stream is from a website broadcasting a sports event or an instant messaging client transmitting from a webcam, there are several things you can do if the streaming is delayed or stalled. Numerous factors can affect this stream. Deleting your computer's cookies, using a different media player or turning off running programs can allow you to view these streams without delays.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted.
Open your Web browser and delete the cookies from the browser. For Firefox, you can do this from the "Tools" button at the top of the browser. For Internet Explorer, access the delete function from the "History" button. Cookies will slow down your browser. Use a different media player to access the live stream from your computer. Your media player may not have the right codecs or plug-ins to access the stream. You might need to reinstall the media player if there has been any damage to the software. Shut down all the programs you aren't using. If you run other programs while you are trying to stream a live video, you could be overloading your system's central processing unit. This can delay the stream. Disable the hardware acceleration. Click "Start," then click "Control Panel" from the menu. Click "Display," then choose "Settings" from the menu. Click the "Advanced" icon, then click "Troubleshoot" from the menu. Click the "Hardware Acceleration" icon. Slide the acceleration slider to the left to turn it off. Add more RAM to your computer. This allows the computer to run faster while using less processing. Refer to your computer's user manual on how to add more RAM to your system.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible Hope this helps.
tip
VOB movies for Acer Iconia Tab A500-Stream DVD VOB to H.264 MP4 to Acer Iconia...
Transfer/Play DVD VOB files to H.264 MP4 for Acer A500 <br />Join multiple DVD vob files into one for Playback on Acer Iconia Tab A500 <br /><br /><b>A VOB file (Video Object)</b> is a container format in DVD-Video media. VOB can contain video, audio, subtitle and menu contents multiplexed together into a stream form. VOB file can contain H.262/MPEG-2 Part 2 or MPEG-1 Part 2 video, MPEG-1 Audio Layer II or MPEG-2 Audio Layer II audio, but usage of these compression formats in a VOB file has some restrictions in comparison to the MPEG program stream. <br /><br />How to convert and play DVD VOB files on Acer Iconia Tab A500? For Acer Iconia Tab A500 can not accept this format. <br />Acer Iconia Tab A500 is also a great media player which supports a lot of media formats including files with XviD, MP4, H.264, H.263 as video format and MP3, WAV, WMA, eAAC+ as audio format. So you need to convert the files before transferring and playing them on Acer Iconia Tab A500. <br /><br />Aunsoft Video Converter is the best <b><a href="http://www.aunsoft.com/video-converter/">VOB to Acer A500 Tab converter</a></b> for you to transfer files to tablet. It makes it easy to transfer VRO files to Android tablet by converting DVD VOB to MP4 for Acer Iconia Tab A500. You may also deinterlace VOB to progressive mode for perfect playback on Acer Iconia Tab A500. <br /><br />Below is the quick step-by-step guide for you to <b><a href="http://canon-videoconverter.com/2011/06/join-multiple-dvd-vob-files-into-one-for-playback-on-acer-iconia-tab-a500/">transfer and play VOB to Acer Iconia Tab A500</a></b> via Windows XP, Windows Vista, Windows 7. <br /><br />Step 1. Load VOB to Aunsoft Video Converter. <br />Run Aunsoft Video Converter as the best VOB to Acer Iconia Tab A500 converter, and click the "Add" button to import the .vob videos. <br /><img src="a500-vob-converter.jpg" /> <br /><br />Step 2: Choose the suitable Acer Iconia Tab A500 format. <br />As we know, Acer Iconia Tab A500 supported video like XviD, MP4, H.264, H.263 format like MP4. Here just take H.264 HD Video (*mp4) for example. Choose Common Video &gt; H.264 Video (*.mp4) as output format. <br /><br />Tips: Click "Settings" to set the Video/Audio Parameters like Size (resolution), bitrate, frame rate, etc to be more suitable for Acer Iconia Tab A500. For example: Set Size/Resolution to 1280*800 pixels. <br /><img src="set-a500-profile.jpg" /> <br /><br />Step 3: <b><a href="http://www.aunsoft.com/video-converter/">Convert/Rip DVD VOB to MP4 for A500</a></b>. <br />After all the above settings, you can click "Convert" to start <b>conversion VOB to MP4 for Acer A500</b>. Only a few munutes later, you can get the generated files by clicking "Open" icon. <br /><br />When the conversion is done, just connect Acer Iconia Tab A500 to Widnows PC via USB cable, and mount the converted videos to Acer Iconia Tab A500. <br /><br /><b>Tips:</b> If you want to <b>join multiple DVD vob files into a large files for smoothy playback on Acer Iconia Tab A500</b>, just check "Merge into one file" to make it.
tip
The best way to convert FLV to MP4
1. What is Flash video FLV?<br /> FLV, short for Flash video, is a video format played in Adobe Flash Player. If you download a video from YouTube, Google Video, Yahoo! Video, DailyMotion etc, it is most likely a Flash video with the file extension .flv. With the wide availability of Adobe Flash Player in most common web browsers, Flash video has become the most popular format for online video delivery!<br /> 2. What is MP4?<br /> MP4, short for MPEG-4 Part 14, is a multimedia container format standard specified as a part of MPEG-4. It is commonly used to store digital audio and video streams, especially those defined by MPEG, it can also be used to store other data such as subtitles and images. Like most modern container formats, MPEG-4 Part 14 allows streaming over the Internet. The official filename extension for MPEG-4 Part 14 files is .mp4, thus the container format is often simply referred to MP4.<br /> 3. How to convert FLV to MP4.<br /> Convert FLV to MP4 is for playing flash videos on different devices like iPod, Apple TV and so on. Generally, there are two ways to convert FLV to MP4: either to convert FLV to MP4 with online conversion services, which can be easily searched in Google or to convert FLV to MP4 with FLV to MP4 converter like FLV Converter. This FLV converter can perfectly convert FLV to MP4, convert FLV to many other more popular video/audio formats. Using the video editing functions it has provided, you can get your flash video cropped, trimmed and logoed during the FLV to MP4 conversion. The tutorial below will show you the easiest way to <a href="http://www.mediaconverter.biz/guide/convert-flv-to-mp4.html">how to convert flv to mp4</a>.<br /> <img src="convert-flv-to-mp4-1.jpg" /><br /> Step 1: Launch <a href="http://www.mediaconverter.biz/">DRM Media Converter</a> and click "Add" to input FLV files.Click "Add File(s)" button on the toolbar or "File &gt; Add File(s)" to load FLV files you want to convert. Or click "File &gt; Add Folder" option to add all files in the folder you select.<br /> All the loaded files will be displayed in the file list, and are all checked by default.<br /> Step 2: choose output format.<br /> The default output format is the one you selected last time. If you want to change the output format, then choose the file, click to open "Profile" drop-down list below the file list or in the "Target Profile" column, and choose the desired format from it. Click "Browse" button to set the destination folder for saving the output files.<br /> Step 3: convert<br /> Make sure all the files you want to convert each have a check box next to them, and click the "Convert" button on the toolbar to start converting all the checked files in batches.<br /> More source: <a href="http://www.mediaconverter.biz/guide/convert-mp4-to-avi.html">best mp4 to avi converter</a>, <a href="http://www.mediaconverter.biz/resources/convert-mp4-to-dvd.html">how to convert mp4 to dvd</a>.<br />
on Apr 27, 2011 • Computers & Internet
1helpful
Mac freezes w/skipping audio streaming video
This is a fascinating problem, because there are so many possible culprits... plugins, Quicktime, networking...
Because it only happens on streaming media, because it comes and goes a week at a time, and because you have a satellite connection, my first suspicions fall on your internet service. However, this would be unwieldy to prove. The obvious experiment would be to carry your computer to a friend's place where you could use non-satellite broadband... but you say the problem comes and goes, and I'm assuming there is no single "video from heck" that is always guaranteed to fail, so a failure to fail wouldn't prove very much.
Another good experiment would be for you, during one of your "good weeks," to disconnect your satellite modem's coax cables while you are streaming one of these videos to see if it triggers the same failure at the Mac. (Powering the modem down wouldn't provide the same failure mode.)
Another: Quicktime Player (as well as VLC) has an "open URL" option. If you use that instead of a browser during a "bad week" to view videos, does the failure also occur? (That would rule out the plugins.)
One thing I can advise you: don't bother running disk repair, this problem isn't anywhere near your disk.
I wish I could point a finger and say "your problem is definitely here," but that isn't going to happen with this problem. The best I can do is provide some tests to help you narrow it down.
Mac freezes w/skipping audio when streaming video
I see that you have reposted this under the correct category, so I will close out this instance and address your problem in the other posting.
tip
Play videos on Xbox 360 and stream videos to Xbox 360
How to play videos on Xbox 360 and stream videos to Xbox 360 – including Blu-ray, DVD movies, and videos in various file formats
This tutorial intends to list out all the video formats supported by the Xbox 360, and explains all the available ways to play videos on Xbox 360 in HD quality or stream videos to Xbox 360. The videos include Blu-ray movies, standard DVD movies, and various other videos, such as ISO image file, Camera footages, MKV, MTS, VOB, M2TS, TS, TP, FLV files, etc.
Let's Get Started.
Part 1: The details of Xbox 360 supported file formats
1. AVI:
File Extensions: .avi, .divx
Containers: AVI
Video Profiles: MPEG-4 Part 2, Simple & Advanced Simple Profile
Video Bitrate: 5 Mbps with resolutions of 1280 x 720 at 30fps.
Audio Profiles: Dolby Digital 2 channel and 5.1 channel, MP3
Audio Max Bitrate: No restrictions.
2. H.264:
File Extensions: .mp4, .m4v, mp4v, .mov
Containers: MPEG-4, QuickTime
Video Profiles: Baseline, main, and high (up to Level 4.1) profiles.
Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. Audio Profiles: 2 channel AAC low complexity (LC)
3. MPEG-4:
File Extensions: .mp4, .m4v, .mp4v, .mov
Video Profiles: Simple & Advanced Simple Profile
4. WMV:
File Extensions: .wmv
Container: asf
Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps.
Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless
Notes: You can not mix and match the video and audio codec outside of the above defined lists randomly.
Part 2: Different ways to play videos on Xbox 360
With regard to playback videos from a USB storage device, please note that the Xbox 360 will support as big of a storage device as you can format using FAT32, and the maximum size of any single file on FAT32 is 4GB. Besides that, the maximum file size for an AVI, MPEG-4 Part 2, and H.264 file that can be played is 4 GB as well. To play a file greater than 4GB on Xbox 360, you can use Windows Media Player 11 and the Zune software to stream videos from your PC to Xbox 360 console, and notice that the file format must be WMV only. Why is it so special with a WMV file? That maybe WMV is a codec developed by Microsoft.
Well, that is to say, to some extent, we can consider WMV as the optimal format to play or stream to Xbox 360. When you are gonna watch a Blu-ray/DVD movie, or an MKV video, or some files else that are out of the range of Xbox 360 workable formats, what is your solution? We usually make use of Pavtube Blu-ray Video Converter Ultimate to do format conversion. Why do we choose it? Mainly because of its splendid output quality and its feature of an all-in-one application: a Blu-ray ripper, a DVD ripper, and a versatile video converter.
Part 3: How to convert Blu-ray/DVD and videos to WMV for play/stream on/to Xbox 360
We have mentioned in the above contents that the program we will use is Pavtube Blu-ray Video Converter Ultimate. Go to find a step-by-step instruction from the following part.
STEP 1: Load Blu-ray, DVD or other video files into this program
Click "Add Video" to import video files, and click "Load DVD" to import Blu-ray or DVD files.
STEP 2: Select subtitle and audio track
Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track as your choice. Your selection can be reviewed in the preview window to the right hand of the main interface.
STEP 3: Select WMV as output format for Xbox 360
Click on the drop-down list at the opposite side of "Format", and then choose "WMV3 (WMV9) (*.wmv)" as output format.
STEP 4: Do optimal settings for the output WMV files
Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the popup window. To make it excellent for playback on Xbox 360, you can follow the optimal settings as below:
Video codec: wmv3 (the default one)
Resolution: 1920*1080
Bitrate: 150 kbps
Frame rate: 30 fps
Audio codec: wmav3 (the default one)
Sample rate: 48 khz
Bitrate: 320 kbps
Channels: 5.1 Channels
Do remember clicking "OK" button to confirm your settings.
STEP 5: Click "Convert" button to start BD/DVD ripping or video conversion
Once finished, click "Open" button at the bottom to get the output WMV files for Xbox 360, which now is prepared for playback or streaming.
Part 4: How to stream videos to Xbox 360
Well, as we have mentioned in Part 2, there are at least four ways to stream videos to Xbox 360, from Windows Media Center, Windows Home Server, Windows Media Player 11, and Zune Software. Actually, lots of online articles have detailed the setups and operating steps, just check the following links to find the one which is most suitable for you:
How to stream videos to Xbox 360 via Windows Media Center
How to stream videos to Xbox 360 via Windows Home Server
How to stream videos to Xbox 360 via Windows Media Player 11
How to stream videos to Xbox 360 via Zune Software
I recently purchased a hp 2133 notebook and when I stream videos, be them online or downloaded, it keeps skipping, the picture doesn't flow smoothly. Is there any way to improve the viewing quality of...
No. If your movie was downloaded from the internet the resolution of the film can not be improved. However you can improve the movie reproduction on your system (skip) adding more memory to your system.
HI.I was watchinglive streaming but there is a eror sudenly.this eror:rtsp://78.129.143.64/broadcast/pull/81.31.32.47:2030/broadcast/pull/81.19.7.50:3051/stv3.rmvb Can you help me...
Streaming audio/video quality can be affected by connection rate and Internet congestion. Many types of interruptions between your computer, your player, your computer's OS, your local network, your ISP and a streaming server can exist and cause trouble....
When you listen to the live audio/video stream, the sound or video skips, cuts out or buffers if the player doesn't have enough network bandwidth, it will buffer. Try increasing your player's buffering setting.Also:
  • Make sure you are choosing the appropriate bandwidth version of a media stream based on your Internet connection.
  • Make sure you are choosing the appropriate bandwidth settings in an Internet media player or streaming audio/video recorder.
  • Make sure NOT to download applications or files while watching/listening to media streams. Your Internet connection is shared between all open applications including your web-browser, your download manager and your streaming player. Closing applications that use your Internet connection simultaneously with your streaming player may reduce buffering.
  • Close other unnecessary applications that may be open on your computer. Reboot your computer. If you have lots of other programs open, they may be using too much processor time and/or RAM for the player to work properly.
  • Make sure your Internet connection is fast enough to reliably listen to streaming audio and/or watch streaming video online. High speed Internet connection is recommended.
  • Make sure your computer is fast enough. If your computer is old, it might be too slow to play an audio/video stream regardless of what else it's doing.
  • Update your media players and streaming audio/video recorders regularly.
Internet congestion can slow down the delivery of the stream, make it difficult for you to connect or cause buffering. Often the interruption is temporary. Please try to connect a few times at different times of the day, if possible. If you repeatedly have problems connecting, please notify your ISP - there are often quick fixes they can make when they learn about your issue.
Try the above steps you will find a solution to your problem....100% it will work.....
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
