Question about Dryers
The only dryer was a 3 prong system the new one is a 4 prong what do i have to do to the out let to make it a 4 prong sence there is only 3 wires in the box
  • Dryers Master
  • 43,501 Answers
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Apr 09, 2011
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 03, 2010 | Dryers
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
I am trying to change a 3 prong dryer plug to a 4 prong
You are correct, the green wire is ground. You may be able to connect to the same location as the green wire from the unit.
The white is neutral and the red and black are both 110V (your unit uses 220V).
Here is a link to a picture. I hope it helps:
http://repair2000.com/cord.html
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
I have a Maytag dryer with a 3-prong plug. My new
The following link explains how to convert a 3-prong cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (WHITE) and Ground (GREEN or BARE) wires are installed. In a 4-wire configuration, the neutral and ground are INDEPENDENT of each other and are not connected together.
Read through the link and let me know if you have questions. I hope this helps you.
Sep 02, 2009 | Dryers
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Dryers Logo
149 people viewed this question
Top Dryers Experts
