Question about Maytag Performa PAV2200
I have a Maytag Performa pav2200. It is about 12 years old and has never needed any service. Recently, however, during any agitation cycle, I have to hold the drum because it turns while agitating. This is preventing the clothes being dragged down to the botton of the drum. The drain cycle works fine and the spin cycle has no problems either. Is it possible that the belt is worn? It is the original
  • 1294 Answers
SOURCE: Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 26, 2007
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
mastatech
  • 478 Answers
SOURCE: Maytag Performa PAVT920AWW noise in wash cycle no agitation
Your main tub bearings need replacing at least a 200.00 repair. The parts alone are about 80.00 and a few hours labor.
Posted on Mar 29, 2009
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
  • 212 Answers
SOURCE: maytag performa squeals when agitating and
replace tranny
Posted on Jun 20, 2009
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Performa Washer is making a scratching noise during the spin cycle. Any ideas what it could be?
The problem could be due to few things.
1.There is a seal underneath the nut that holds the air bell housing on.
2.A faulty agitator component,there is a plastic hub that connects the
agitator to the motor and this can become worn.
3.Finally it can be the transmission,this is most likely your problem.
Apr 11, 2010 | Maytag Performa PAV2200
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Agitator
A serious transmission problem, I doubt that it is worth the cost of repair, sorry.
Aug 21, 2017 | Maytag Performa PAV2200
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
