Question about Hunter 52" Ceiling Fan With Light And Remote Control
Grande Lodge Fan
I need the directions. I accidentally threw them out with the box, and both fans are not working.
I have an existing ceiling fan with an add on remote control. Does anyone have a wireing digram or can tell me how to wire it up. The switch on the wall kills all the power coming to the fan. I have the color wires wired together(pink to pink , etc.) It is a hunter add on divise. Model # CP911OR
Posted on Aug 19, 2008
We're is the fuse for fan speed on fiat punto grande 06
go to auto shop and look at their chillton manual on it or find your fuse box it may tell you.
Jan 08, 2013 | 2006 Fiat Grande Punto
Hunter 'lodge' ceiling fan w/light: all switches 'on' and light blinks???? what do I do to correct problem?
if problems with the light blinking, remove watt governor inside fan, for lights. and wire the lghts directly. this should fix problem. the watt governor is a small black box to reduce wattage on the lghts. just remove it and wire lights directly. have a good one !!
Dec 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter Lodge Fan will not remain on HI... will go down to LOW
have the wiring checked for proper and good connections....other than that, the control module in the fan ( the receiver) is defective.
Jul 25, 2009 | Aloha Housewares (93645) Ceiling Fan
Cooling fan replacement for my hp 6624A dc power system
TAKE 9VOLT BATTARY TO SEE WITCH WAY THE AIR BLOWS, UNLESS BY LOOKING AT THE POWER SUPPLY HOUSING AND UNDERSTANDY WHAT THE ARROWS ON THE CACE SHOWS DIRECTION,
DO YOU HAVE VOLT METER, YOU NEED TO TEST TO FIND OUT OUT WHAT 12VOLT + OR - IS ON THE POWER SUPPLY , SOMETIME FAN MANIFACTURE WILL GIVE A CABLE TO PLUG INTO YOUR POWER SUPPLY TO MAKE YOUR FAN TO OPERATE THE RIGHT WAY, IF YOU NEED MORE HELP WITH THIS YOU CAN CONTACT ME THREW THIS SITE
CANDYMANGANDY
Jan 27, 2009 | HP (D6021-63034) Fan Assembly
Remote receiver faulty
That is correct you need a new receiver for the fan. The other problem that could have happened is when you replaced the batter in the remote you accidentally hit the dip switches and changed them. That is the box that has 4 white switches on it. One is in the remote and one is one the receiver that goes in the fan.
Good Luck ANd Please Rate FixYa!
Dec 29, 2008 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
2000 Saturn SW cooling fan
it sounds like your computer is faulty the temp sensor run threw the computer
had another car and was chasing my tail till i changed it
Dec 23, 2008 | 2000 Saturn Ls 4dr Sedan
Remote receiver doesn't fit
ok since you have the power off move ceiling fan box electrical box over place remote above the electrical box with the antenna sticking out replace fan power up you might have to go into attic to place the remote sensor and antenna down to outside of fan i had the same problem myself i made a cut in drywall ceiling big enough for sensor unit let the antenna hang out placed up there
i used a wall plate cut in half to match the hole i just made or you dry wall back up but if remote goes out theres now no way to get to sensor unit
little cut in drywall place sensor threw antenna hang down put plate over hole
May 26, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
369 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
