Question about Toshiba Computers & Internet
The sound comes and goes on my Toshiba C655 laptop. It goes out then comes back on its own. All indicators say the sound is working fine, the speakers are fine...the mute is not on...no help with troubleshooting. This is the third time this has happenend. The laptop is less than 6 months old.
  • Toshiba Master
  • 27,725 Answers
If the laptop is less than 6 months old you should still have warranty you could retutn it on a warranty issue before you touch anything but you could attempt some basic troubleshooting
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 09, 2011
I have a Toshiba laptop model# C655-S5501 with a bad keyboard (Gator Aid!). I can't find an exact model # match through Amazon. Will the "Eathtek NEW Keyboard For TOSHIBA SATELLITE C655-S5128 C655
Check eBay. I've been working on computers for years and order ALL of my replacement keyboards through eBay. I just found 9 of them after entering your model number; about $16 with free shipping. Sarawill82 hit the nail on the head for the replacement; you tube is your friend if you're doing it yourself. If it doesn't have your exact laptop, look at other videos. It will give you an idea what you need to look for to replace the keyboard.
It beats paying a computer store a $45+ bench fee, and it will only take you about 15 minutes as a novice.
Don't try to clean it; you could cause more extensive damage than just replacing the keyboard.
Jan 16, 2015 | Toshiba Replacement Keyboard
Z,/,?,and all four directional keys stopped working on my toshiba satillite c655-5128
The keyboard will more than likely need to be replaced, there are no user servicable parts. Go to www.ebay.com type make and model of laptop, refine search to keyboard.
Aug 31, 2012 | Toshiba Satellite C655-S5140 Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Hello there, I own a toshiba c655-s5049 laptop about a year. When I connect a charger taskbar icon shows plugged-in, not charging and the front panel power/battery indicator lights green not orange. When...
Take some alcohol and a q tip and wipe the battery terminals and the terminals on the battery compartment. The laptop not getting a good connection with the battery
Aug 07, 2017 | Toshiba Satellite C655-S5049 Notebook
The sound on my toshiba satellite c655 s5068 laptop does not work after sleeping.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If same thing happened, uninstall and reinstall the audio driver. Go to start/type device manager in search box/click sound video and game controller/uninstall the audio driver and restart the laptop to take effect. Once the laptop booted up wait for the message that the device driver is successfully installed or check if the audio driver is back in the device manager. Then test the sound.
Mar 17, 2011 | Toshiba Satellite C655-S5068 Notebook
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
Feb 16, 2011 | Toshiba (P000257700) Microphone
Have a toshiba c655 & forgot my password / as soon as I turn it on it- says to enter current password. It will not let me use F2 or F12, it goes right back to enter current password. How can I solve...
Have a toshiba c655 brand new in the box as soon as I turn it on it- says to enter current password. It will not let me use F2 or F12, it goes right back to enter current password. How can I solve this problem?
Oct 12, 2010 | Toshiba Computers & Internet
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
271 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
