Question about iiyama OSP12 1 Speaker Speaker
Hello 0 just purchased a e2008hds, but can't get the speakers to work. Can you please help? Thanks.
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 09, 2011
Where I can buy another set of this type of speakers? Please send all info. Thank you.
I dont think you will be able to purchase the A215 speakers as they are End Of Life and DELL nomore ships these speakers.Go to the below link and order the speakers according to your requirement.
http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6178&cs=04&l=en&s=bsd&~ck=anav&nf=34533~0~325895&navla=34533~0~325895
Jan 03, 2011 | Dell A215 Computer Speakers
Hello, I need to know the wiring connection destinations by color for all wires coming out of the back of the Pioneer DEH-P9200R car audio receiver. Thanks in advance. John from Baltimore
If this helps you then please help my rating,voting for me would be great too thanks.
Black - Ground
Blue - Power Antenna / Control for an AMP
Orange - Constant 12 Volts
Red - 12 Volts when the ignition is on, 0 Volts when it's off
[Speakers]
[Front]
Gray - Front Right Positive
Gray Black - Front Right Negative
Green - Front Left Positive
Green Black - Front Left Negative
[Rear]
Gray Red - Right Rear Positive
Black Gray - Right Rear Negative
Green red - Left Rear Positive
Black Green - Left Rear Negative
Nov 15, 2010 | Car Audio & Video
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
Hello Bogue Engineering, They must fit the Sony STR-KS370. I need new speaker connectors for the 5 channel speakers. green, purple, blue, gray, red and white. I dont want to splice, where can I...
HI,
This is Gary from Bogue Engineeing and any of our universal 4,2mm connectors and cables will work perfectly with your system. Please goto our website at
www.BogueEngineering.com
Thank you!
Aug 18, 2010 | Audio Players & Recorders
Need a part number and a good place to purchase a new engine oil dipstick
Hello. This is an item that you are most likely going to have to order from a Dodge dealership. Regards, Joe
ps - please rate my answer as helpful. thanks
Feb 16, 2010 | 1998 Dodge Ram 1500 4WD
Looking for codes or a code for a magnavox tv.. I curently have knology as my cable provider
Hello Try these..
Magnavox 0 0 5 4 ,1 2 5 4 ,0 0 3 0 ,0 1 7 9 ,0 1 8 7 ,0 0 9 6 ,
0 0 2 0 ,0 1 8 6 ,0 3 8 6 ,0 0 2 4
Please rate the help++++Thanks for using FIXYA
Sep 25, 2009 | Televison & Video
Service manual logitech z 5300
Enclosed Image is from Z-5300 Manuel
Nov 28, 2008 | Logitech Z-5300 Computer Speakers
Connecting the 901 series VI equalizer
hello
please make sure your receiver has a tape monitor switch on the front panel or pre-in/out sockets at the rear. only then all sources will play thru the bose equalizer. also remember if you need a 5.1 or greater setup, you will need 2 amps/receivers.
hope this helps
May 27, 2008 | Bose 901 VI Main / Stereo Speaker
Error on windows load
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
Cannot unlock security code for nokia 6288 because my daughter key in while playing with the handphone,so now i have problem using it.It only says "pls key in personal security code to unlock HP"
hi i can help you but i need your phones imei number its located on back of phone under battery its 15 numbers long and will look like 123456/12/123456 once i have that code i can then get the master unlock code for you this will then reset the security code to what it was when the phone was purchased ok so ill wait to hear from you.
Most unternet sites charge for this service but as i dont pay i dont charge speak soon
Feb 01, 2008 | Nokia 1600 Cellular Phone
iiyama OSP12 1 Speaker Speaker Logo
43 people viewed this question
Top iiyama Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an iiyama Audio Player and Recorder Expert? Answer questions, earn points and help others
