Question about Sharper Image SO225 CD Shelf System
My Sharper Image SO225 door was stuck open just a little bit for a few years, in a room that I didn't really use. I was happy to see this little gem again and replaced the batteries in the remote. So far, the only part not working is the cd player. It moves from disc to disc but won't spin. Could this be a dust problem, since the door wasn't completely closed? Any help with this is greatly appreciated.. Renee
    Top Expert:
  • Sharper Image Master
  • 45,112 Answers
It could be dust, but more likely the player mechanism has failed.
Posted on Jul 23, 2017
3 Suggested Answers
Grubhead
  • 5487 Answers
SOURCE: Disc belt needed
You need only measure the diameter in MM and put that and "CD/Cassette drive belt" into google and you should find a supplier. A few MM either side shouldn't make difference. Drive belts etc are none specific makers by the way.
Posted on Jun 02, 2010
Testimonial: "I really appreciate the advice!"
SOURCE: Sharper Image 3-CD model SA248 Doors opening problem
The bands that allow the cogwheels to turn, snap and needs to be replace.
Posted on Nov 27, 2010
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
Hello FREIDA GRAYDEN,
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
HAPPY FREIDA (I think).
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
expect YOU to be TOTALLY SATISFIED.
Carnac the Magnificent
https://www.amazon.com/HoMedics-Cool-Mist-Ultrasonic-Humidifier/dp/B00EW1QJPS/ref=pd_sbs_201_2?_encoding=UTF8&pd_rd_i=B00EW1QJPS&pd_rd_r=S79PF7TS0FVV4D24Y2GP&pd_rd_w=jrPo2&pd_rd_wg=POkzf&psc=1&refRID=S79PF7TS0FVV4D24Y2GP
Jan 11, 2018 | Humidifiers
I have a Sharper Image No-Hands deluxe auto can opener model # SI212 I no longer have the manual and need to change the batteries.
http://www.onetouchproducts.com/pdf/CanManual.pdf
This is really simple. Put your finger in the middle of the bottom (flat side) and slide the WHOLE bottom towards you. I had a problem figuring it out too because it seemed like they were indicating you only slide the one little section back. Good luck.
May 25, 2011 | Sharper Image Kitchen Appliances - Others
I've had a Labtec LCS 2408 for several years, and been happy with it. However in the last few months, the volume control got noisy, worked intermittantly, and then quit altogether. How can I take...
Well if you want to try and can't get it opened up just take the knobs off and vacuum it out, then if you have some compressed air blow it out, and if you are really protestant spray a squirt or two of WD-40 in there. Not a bunch just a little bit, sometimes if it has residue built up in there the WD-40 will break it down. Good luck, if determined to take apart make sure you pull any rubber pads off the bottom and remove those screws too, it will most like snap together pretty tight since it's a speaker and they didn't want it rattling.
May 11, 2011 | Labtec LCS 2408 Computer Speakers
How do you get the battery door open on the sharper image u-video camera?
The battery door is at the bottom of the camera, just below the little box with THE SHARPER IMAGE in it and opens easily ...if you know the trick. (The tripod mount is in the bottom of the door.) using your thumb, press down on the tripod screw hole and push on the door from the front of the camera toward the rear and the door pops open. Reverse the procedure to close.
Dec 25, 2010 | Cameras
I have 4 units and all of them at the same exact time without any warning like hissing..the red light turned on. When I removed the inside part it looked like paper had caught on fire. In fact its like...
The trouble began in 2003 when Consumer Reports magazine published a report claiming the expensive air cleaners don't clean air. The magazine later claimed its tests showed that Sharper Image's Ionic Breeze Quadra Silent Air Purifier and four other units also release potentially unhealthy levels of ozone.
Read more: http://www.consumeraffairs.com/news04/2008/02/sharper_image.html#ixzz0VATFAuRq
Oct 27, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Sep 10, 2009 | Sharper Image Audio Players & Recorders
Adjusting calibration
try adjusting the anti skating device near the main tonearm pivot? set it another notch and try it again? if not repeat by setting another notch till your happy with the playback?
Apr 27, 2009 | Sony PS-LX250H Turntable
We have a Human Touch Sharper image chair purchased online from Sharper image. The remote control has come detatched from the electrical wiring. It has pulled out. Our electrician suggested that we ask if...
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Sharper image ionic breeze air cleaner
Jul 15, 2008 | Sharper Image Professional Plus Ionic...
SHARPER IMAGE AIR CLEANER HAS STOPPED WORKING, NO BREEZE COMING FROM UNIT AND BLADES ARE NEVER DIRTY. THE "ON" LIGHT IS ON.
Sharper Image no longer supports Ionic Breeze machines. They recalled them a few months back since Consumer Reports and the EPA has determined that they weren't working and can even cause health hazards during usage. Sharper Image sued an lost forcing the company in bankruptcy.
The Consumer Products Safety Commission is going to make a decision on sales of all ionizers in the U.S. by the end of the year. It's looking like you won't be seeing these around much longer.
Jul 06, 2008 | Sharper Image Ionic Breeze Air Freshener...
Sharper Image SO225 CD Shelf System Logo
50 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
