Question about Gaggia Titanium Espresso Machine
Same problem with gaggia
The rising cycle is in a loop, probably I've fill up the tank about 30times, also I've saw a comment from another person about removing the brewing unit and it seems that doing the rising cycle, the brewing unit gets lock, and can't be removed...
what can I do ?
thanks in advance
  • gaggiu Aug 06, 2008
    btw I've started the rising cycle because the machine was stuck on the ventilate situation and I couldn't get it working even reseting the settings to factory default.
  • 515 Answers
Did the machine stop after a while?
When the rinsing cycle run you have to let it go to the water tank is empty and the machine **** air in the system, then you fill up with new water. If it not reset then i think there are something with the printed circuit card.
Let me know if you get your machine to run again.
/Mirran
Posted on Aug 06, 2008
Gaggia syncrony compact digital expresso maker says fill water tank but water tank is full
Check the float in the tank that indicates the water level to the sensor. They often fail to float, solution is to either replace the tank or jam something plastic under the float to lift it to the top of its slot.
Jan 01, 2016 | Gaggia Syncrony Compact Digital Espresso...
Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
May 02, 2010 | Gaggia Titanium Espresso Machine
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Rising cycle not stopping
If it stops after a half cup of water then you have to replace the flowmeter.
/Mirran
Aug 06, 2008 | Gaggia Titanium Espresso Machine
Gaggia Titanium
Do you mean the brewing unit you not can get out?
Jul 12, 2008 | Gaggia Titanium Espresso Machine
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Frosen
The duration of the rinsing cycle is equal to the amount of water you have in the water tank. I don't believe they tell you this anywhere in the manual! I own a Titanium SS and it rinsed and rinsed and rinsed the first time I performed it! I figured out it will just keep going until the water tank sensor tells the machine it is out of water which is equal to saying to it: "Thanks for using all the water i wanted you to use to rinse, now you're finished." It takes a LONG time if you fill the tank. If you keep filling the tank, it will just KEEP going. Be patient, let the tank run out of water and this will trigger the end of teh cycle. Hope this helps, Tony.
Sep 11, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
260 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
