Question about LG Washing Machines
I have a LG WD-10485TP Washing Machine. It washes OK but does not Rinse the water out ? Any ideas ?
4 Suggested Answers
  • 1294 Answers
SOURCE: lg wd 80290np
Do you clean out your outlet filter at times; this should be done according to your usage. The door is 4" square usually at the bottom of your washer; open up, expect some water, clean out and refit.......
Posted on Sep 26, 2007
  • 6277 Answers
SOURCE: my LG 6.5kg WD-10150-TP washing
(Sorry if I have answered this already! It is VERY similar to one which I answered earlier!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
  • 6277 Answers
SOURCE: my LG washing machine WD-10485TP
'CL' for LG washers stands for 'Child Lock'.
To release hold down 'temp' and 'eco/rapid' together, then release!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 27, 2011
LG WD-10485TP PROBLEM CL
not work can you tell me an other method if you know
Sep 21, 2013 | LG WD-1280FHD Front Load Washer
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
My LG washing machine WD-10485TP displays CL, what can I do?
John C.
Jul 27, 2011 | Washing Machines
Lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had a similar problem i unplugged the machine and left it stand for 8 hours .. it works ok..
Apr 22, 2009 | LG WD-16115FD Front Load Washer
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Lg wd 80290np
Sep 25, 2007 | LG WM-2277HW Front Load Washer
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
145 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
