Question about Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024 x 768, 450:1 => Model POWERLITE 7850NL Monitor
Hello. i have an Epson projector model # H309A with symptom: turn on, have display but no pictures on any inputs. do you have any suggestion? thank you for all your help.
2 Suggested Answers
luciana44
  • 292 Answers
SOURCE: picture upside down after installing on ceiling
Try Uninstall the projector and install again.
luciana44
Posted on Aug 25, 2009
No picture
Scroll through the inputs using the input button on the remote control to see if you can find the right input. Hope this helps.
Jan 18, 2014 | Epson 8350 Projector
I have a DELL XPS 15 Laptop. I tried to connect the laptop to different lcd Projectors using HDMI to VGA connector. The laptop could not be connected with any of the lcd projectors and no projection on the...
Hi
Sure can be fixed.
1st of all you need to connect the projector with your laptop turned off. One the laptop has finished booting and loading windows. Hit the Fn+f4 or f7 key to switch between the displays then you will get the display.
But if this also does not give display then you can check with the projector with Video INPUTS (Eg. Input 1 / Input 2 etc.,)
Jul 21, 2011 | Epson EMP-S5 Projector
I have a Sharp DT400 projector. I replaced the lamp, and the unit powers on, and displays a picture during warm up but only for a few seconds. The lamp indicator and power lights go back to red and unit...
If you try to turn on the projector a fourth time without replacing the lamp, the projector will not turn on.
Press ON, INPUT, UNDO, left arrow, ENTER and right arrow on the projector in order, and then press ON.
The lamp 0000H is displayed on the lower left of the screen.
Mar 26, 2011 | Sharp DT-400 Multimedia Projector
CAN I PLAY TV THROUGH MY EPSON MOVIEMATE?
you can play TV through any projector if you use an external tuner. This could be a satellite tuner, freeview box of similar. It has some type of aerial, cable or satellite input and handles channel changing etc, and sends a picture to any attached external display.
Most tuner type devices will have a Scart or 3 x RCA outputs, modern equipment may have DVI or HDMI. Avoid HDMI initially if possible would be my advice, simply because the copyright protection can be a real pain. You'll need to make separate provision for audio (eg, attach your hifi to the tuner)
Feb 20, 2011 | Epson MovieMate 30s Projector
My Epson proxima is displaying pink. I did reset and replace cables and bulb. Any suggestions
I've seen the screen go pink when the video input is set to the wrong type (composite instead of RGB). Try each input type to see if it goes away.
Jan 25, 2011 | Epson PowerLite® 83c LCD Projector
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
Emp-s1
Pls change the display settings of your laptop to 800x600 or 1024x724 then check. The projector SVGA.
Pls tell if you are not able to solve the problem.
Viren
Apr 12, 2008 | Epson EMP S1 Multimedia Projector
Computer Screen Image too small when shown through LCD Projector
You may have to setup the EXTERNAL resoloution for a bigger picture than can generally display on the lappy's screen... there is uaually a setting for the dual display setup... Right Click desktop and click Properties, the video settings can be acessed from there... Also ensure ya have the latest most up-to-date drivers for ya lappy's Video too.
Feb 08, 2008 | Acer Aspire 5610-4648 Notebook
Epson projector issue
I've found my solution. My troubleshooting info said to go to "signal" and make sure that "auto" was turned on. However, I couldn't find "auto" when I first tried. There are two places where signal comes up. The second one is under "set-up" and that is where you turn "auto" on. It works perfectly now. I hope this helps. For the icons, make sure you have "mirror image" turned on in your displays preferences if you're on a Mac. Good luck.
Dec 14, 2007 | Epson PowerLite 62c Multimedia Projector
669 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
