Question about Williams (5009622) Ceramic Gas Wall Mounted Panel Heater
I'm unsure where to actually light the pilot. I do understand how to find the pilot knob and press it in.
  • 1,420 Answers
OK, the knob is located on the gas valve. Now from the gas valve, look for a small dimeter aluminum tube that goes into the burner chamber. There may be a removable door that allows you to insert a long match or grill started into the burner chamber. Usually there is a red button that snaps and directs a spark to light the pilot. Maybe your is long gone or hiding in an awkward spot. Good luck.
Posted on Apr 09, 2011
Help! I have a cozy wall heater model W355F-D. I have never ever lit a pilot light in my life and honestly, Im a little nervous. Can you maybe help me and walk me through it?
You should have control knob on the gas valve that has off, pilot and on , turn knob to pilot and hold in you should have igniter button press this in and it will spark at the pilot you may have to press this a few time to get pilot to light . when pilot is alight still hold knob in for 30 seconds then turn to the on position .
Nov 19, 2016 | Cozy Heating & Cooling
Lennox G10 pilot light is out how do I light it. There is a red button next to the knob that if I press down the knob turns. Help!
Turn knob to pilot press down red button light pilot hold red button down for 45 secs let go of red button turn knob to main flame should light .
Oct 29, 2016 | Heating & Cooling
How do you light the pilot
Turn the gas knob to the pilot setting, press it in and hold it. You should hear gas escaping while in this position. Do not let more than about 10 seconds of gas out at one time as it may pool. Light the pilot while holding the gas knob down for a minute. Release the gas knob (the pilot flame should stay lit) and turn it to the ON position. To make sure the gas heater is working properly, turn up the thermostat and see if the heater heats up. How To Light The Pilot Light On Gas Heater
Oct 19, 2016 | Heating & Cooling
How can we ignite the pilot switch
The directions are on the inside cover of the water heater as well as on the paperwork you received with the unit.
If you have none of these, get the make and model number of the unit and look it up on the internet.
General directions to light a gas appliance:
1.Turn the switch to, "Off"
2.Remove the 2 panels at the base of the unit.
3 Identify the pilot device.
4.Get a long lighter or match on a stick that reaches the pilot.
5.Turn the gas knob to the, "Pilot" position
6.Light the match and put it next to the pilot while pressing down the knob
7. Keep the knob pressed for about 45 seconds after the pilot lights
8. Let go of the knob so it's in the, "up" position
9. Turn the knob to the, "On" position
-the water heater should fire up in under a minute.
10. Put the metal panels back into position.
Jul 14, 2014 | Honeywell VR8200C6008
Pilot light went out
open the inspection door at the base of the unit ,usually at the front of the heater.There will be a round knob with On,pilot and off ,turn the knob to off. Go and have a cuppa. The air inside the gas line has to disapate.After 10 mins turn the knob to pilot, press down on the knob ,holding it down and at the same time press the ignition button several times and peer into the unit to see if there is a flame. If so continue to hold the knob down for one minute.Release the knob and turn to On. Your unit should start to heat straitaway. Good luck
Mar 12, 2013 | Water Heaters
How to light a pilot
Turn the knob on the gas valve t the PILOT position. Press down on the knob so that gas can get to the pilot. Light the pilot. Keep holding down the knob till the thermocouple gets hot enough to hold the safety magnet open and keep the pilot burning. Then move the knob to the ON position. Once that is done raise your thermostat setting till the heater comes on then adjust according to you comfort and party on Amigo!
Oct 27, 2012 | Heating & Cooling
How to light the pilot on a dearborn room heater
Turn the knob to PILOT. press the knob down. Light the pilot and hold the knob till the pilot stays lit by itself. Then advance the knob to the ON position. Turn up the thermostat.
Jan 02, 2010 | Heating & Cooling
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Williams (5009622) Ceramic Gas Wall Mounted Panel Heater Logo
75 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
