Question about Canon PIXMA MP240 All-In-One InkJet Printer
How i put new cartridge where it open - Canon PIXMA MP240 All-In-One InkJet Printer
Where is the drum on the MFC-8860DN and how do I remove it?
The drum is part of the laser toner cartridge
Open the front door
Press the square button in the center of the paper receiving are, it is marked with a small triangle
Press and pull, it will open a door showing the toner cartridge
Pull out the toner cartridge
The top part is black and the bottom assembly is grey
There is a blue little latch in the right side of the cartridge
Press the latch and the toner cartridge will be release
Remove the toner cartridge.
You need to replace the grey bottom assembly with a new one
A compatible assembly, which will have a new drum, will cost around
$30 at amazon an oem around $70
Reassembly and reinstall in reverse of the disassembly
I hope this was helpful
Mar 17, 2015 | Brother MFC-8860DN Printer
How to replace ink cartridge Brother MFCJ415W
It's a fairly straightforward process to replace the ink cartridge on the Brother MFC-J415W. All you need to do is open the ink cartridge cover, remove the color that you're replacing, and put in the new cartridge. Before putting in the new cartridge, however, you must turn the green knob on the yellow cap clockwise until it clicks. Then you put it in the printer and you should be good to go.
Apr 20, 2012 | Brother MFCJ415W AllInOne Inkjet Printer
HOW DO I CHNGE THE CARTIDGE.?
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
3. Open the control panel and cartridge compartment cover (it will click and remain open).
4. Pull the cartridge toward you and remove it.
3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
5. Close the cartridge compartment cover and control panel.
6. Press Start/Enter.
7. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
How do you open for ink replacement?
Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
  1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
  2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
  3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
Installing a new print cartridge Follow the steps below to install a print cartridge.
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
  2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
  3. Close the cartridge compartment cover and control panel.
  4. Press the Start/Enter button.
  5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
for more information follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
HOW DO I REMOVE THE OLD CARTRIDGE TO REPLACE IT WITH A NEW ONE?
Hi! If you wanna replace the the old one with new one, you need to open the cartridge compartment.
Open the compartment from the front only after turning on the Printer.
After opening it, hold the cartridge "thumb on top of the cartridge" and give little pressure on top to remove it and watch it how it comes out and remember it, to put a new one in the same way.
In case you forget how it came... put the new cartridge in its replacing location, and push it in with less force.
Hope it will be helpful for you...
Peace!!!!
Dec 21, 2009 | HP PhotoSmart C4180 All-in-One Color...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Where in the printer should I open to put the new cartridges
THE CARTRIDGES LIVE IN THE FRONT ...IF IT'S A MULTIFUNCTIONAL , LIFT THE SCANNERLID AND SEE IF THE WHOLE TOP GOES UP OR THERE IS A DOOR AT THE FRONT OPEN IT AND THERE YOU GO ....YOU SHOULD SEE THE INK CARTRIDGES ...GENTLY PULL FORWARD AND UP TO RELEASE AND RE-INSTALL THE NEW ONES ....TADA DONE ....HAVE FUN !
Jul 09, 2009 | HP DeskJet F380 All-In-One Printer
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
Removal of black ink cartridge Lexmark Z35 printer
Put your printer "on", then open the central lid, where "lexmark z35" is written. The cartridges appear.
Open the dark green lid (on the right), same color as your new cartridge. Remove the old cartridge and put the new one in, after removing the tap.
Your printer should print a test page. If it doesn't, go to "printers" in the "control panel" (panneau de configuration in french !), right click on your printer name and chose "properties".
Aug 08, 2008 | Lexmark Color Z35 InkJet
Canon PIXMA MP240 All-In-One InkJet Printer Logo
355 people viewed this question
old marine
old marine
