Question about Canon PIXMA MP470 All-in-One Printer
Installation I am trying to install the printer with the cd and when it comes to conecting the printer all the wires are in place and I triple check everything , then it says its detected the device and it says to wait while the installation is complete then after about 3 minutes it say the device is not detected please check the connection, I have tried every single thing and it has taken me 3 and a half hours trying to install it please help me out.
  • James Beeby Aug 23, 2008
    Im trying to instal MP470 printer from disk and get a message "newer version of MP drivers already exists .. canceling installation" .. MP drivers dont instal and printer is not detected. ! driving me mad - I have even tried to delete the drivers but just getting lost. Any one help?!
  • twilson763 Aug 23, 2008
    I put in the CD and begin the "Easy Installation" and get all the way to the end where it says "printer detected, please wait until the installation process is complete". Then after about three minutes it says "printer not detected".
    I've unplugged, replugged, started and restarted the printer and computer with the same issue happening over and over again. Toll free customer support is available Mon-Sat according to the quick start guide, but when I called (it's Saturday) it says they're closed and are open Monday-Friday only. Frustrating. This should be easy.
I had this problem too - i did notice that the printer shows up in the printer control panel so i tried doing a test page - a dialog box appeared recommending cleaning - see quick start guide manual and do maintenace / cleaning - then manual said do nozzle check pattern - after this i went back to dialog box and clicked ok - and finally finally the test page printed
Posted on Aug 31, 2008
Honda revs up but will not get out of low gear, what's wrong? Worked fine before changing motors
It never hurts to triple check, All conections, all sensors, top off fluids, Check transmission shift solenoids, Vehicle Speed Sensor(VSS), Wiring to all Modules. ECM/PCM, TCM, Power Disribution Center, Fuses and Relays, All harness grounds, Engine Speed Sensor, Throttle Position Sensor(TPS), IS FUEL Injected? Idle Air Control(IAC), Mass Air Flow Sensor(MAS), Manifold Absolute Pressure(MAP) sensor. Manifold air pressure sensor. Torque converter, Coolant Temperature sensor, ETC..... Everything.
Mar 08, 2017 | Honda Cars & Trucks
Installation
uninstall the printer completely and then try installing it back
Aug 23, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer is connected to wireless network but getting offline mess
1st you try to ping the the wireless device ip address if you getting the replay that means your wifi is working fine .check the usb cable also for testing directly install on your pc and check it.
Nov 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a deskjet 840c.i conect with my xp comp with usb cord but it is not runing.give some tips to start printer.
Before connecting the printer put the cd that came with the printer into cd/dvd drive. This is to install drivers for your printer. Follow the instructions that comes on the screen. If nothing comes on the screen then run setup.exe from the cd.
Connect the printer when asked to do so or only after installing the programe.(i.e. drivers). good luck
Dec 18, 2008 | HP xw4600 Workstation Linux Installer...
Driver install problem
I think it's a problem with the Operating Systems .
If you can try to reinstall the operating systems and try to install the printer .
Aug 07, 2008 | Canon PIXMA MP470 All-in-One Printer
Can't install xp - freezes
You need a CD/DVD USB drive.
Ask for one or use a HD 3,5" USB drive, open de HD USB disconect the HD and conect a CD drive, it will work like a CD USB drive.
Jan 10, 2008 | ViewSonic Tablet PC V1100
Mp600 can't load drivers
Try deleting any previous drivers installed,unplug the printer USB from the computer. Restart the computer run the driver CD leave the printer unplugged then when the cd asks for the printer,power it on and connect it to the computer let it install automatically see if that helps good luck.
Nov 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP470 All-in-One Printer Logo
old marine
old marine
