Question about ALLEN PAINTBALL PRODUCTS Allen Bradley Vision Camera 2801-yc
Hello, I would like to find Allen-Bradley Machine Vision Camera 2801-YC Data Sheet or at least connector pinout. Thanks a lot. Vlad
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
My machine still shows the same: call service person c6400. Kindly help me please.
You will have to call a Copystar or Kyocera technician to reset your fuser memory.
Aug 31, 2009 | Kyocera Copystar CS-1820 Black and White...
Need older Raytheon v720/ v820 sounder transducer pinout
Did you find it? i´m triying to get a wiring pinout diagram for a V8010 transducer. Thanks, regards from Spain
Apr 21, 2009 | Televison & Video
Camera alignment for fabri vision scanner.Used in sheet metal shop
There are 8 CCD cameras.Before I can help I need to know what kind of machine you have FV4600 or FV4800? or machine serial number so I can cross reference? Or you can contact the following:
Angel Lee
GaugeOne International
Fabrivision Service Specialist
email: gaugeoneintl@earthlink.net
Cell Phone: 818-381-1568
Mar 02, 2009 | Vision Cameras
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Pinouts for Hirose 41 pin connector on panasonic LCD DL3DE0127BAA
I am attaching the image. This is standard 41 PIN Hirose connector for the LCD TV. It doesnt matter who is the manufacturer because all LCD TV has to abide with the Industry architecture. For more information click this link :
http://www.geocities.com/p9019/lcd/LCD_Panel_Pinout.html
Nov 01, 2008 | Computers & Internet
EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
ALLEN PAINTBALL PRODUCTS Allen Bradley Vision Camera 2801-yc Logo
Top ALLEN PAINTBALL PRODUCTS Home Security Experts
Are you an ALLEN PAINTBALL PRODUCTS Home Security Expert? Answer questions, earn points and help others
