Question about Exercise & Fitness
Cintura sports rowing machine.... The display comes on but the machines digtial display is stuck on 0 for everything ie calories burnt etc... and the word STOP is on constantley? Can this be replaced or fixed to work
3 Suggested Answers
  • 4 Answers
SOURCE: Machine does not register when rowing
You most likely moved or damaged the senser under the seat check if the wire is loose or damaged the the senser it in the center of the bottom side of the seat Good luck
Posted on May 11, 2009
SOURCE: Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Posted on Aug 05, 2010
Body Trac Glider stuck on "stop"
I just got and built this rower today and I had the same issue. I noticed that the wire that is coming out of the frame, near where you make the first connection when building it, was half cut. The connection is made up of two wires, one has a white stripe on it. The white stripe one was cut, it probably got squashed from the frame when I was building it. I simply separated the two wires at the cut point (they are connected by the rubber surrounding them like headphones) and stripped either end of the white striped wire that was cut. I then twisted the wire together and taped it together with electrical tape and it worked! I was going to solder the wires together, but it worked with out it so I didn't. I think the white wire works the counters and the solid black one just tells it to turn on.
Jan 28, 2013 | Stamina Products Body Trac Glider Gym...
The display is lit but no numbers appear except 0 at distance calories speed etc. No number read out present
It sounds like the speed sensor is not functioning causing the 00's and since I don't know Manufacturer and Model # it is hard to say
May 15, 2010 | Exercise & Fitness
I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Sep 20, 2009 | Bernina Sewing Machines
Rowing machine foot plate sensor
thankyou but i managed to phone a sports shop and order my part...many thanks.....****
Sep 15, 2009 | Exercise & Fitness
I have a supermicro processor x7dae with a row 0 channel 1 fault.
3a
Remember to replace the DIMMs in pairs unless you have an exact duplicate spare.
Jan 13, 2009 | SuperMicro X7DAE Motherboard
How accurate are the calorie counters on treadmills and cardio equipment?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Dec 01, 2008 | Endurance TF3i Folding Treadmill
What are the benefits of a Rowing Machine?
One of the major benefits of the rowing machine is that it assists in strengthening the torso, the upper body where most of our main muscles are located. In addition to, legs is constantly work out although in the lifestyle of today, the area around the upper body is used more than the legs. The use of resistance to workout the area around the upper body significantly contributes to improving the core strength of the chest, shoulders and forearms. With improved strength, it gives rise to an upper body strength that is more stable and solid to carry out our day-to-day tasks easily. The legs are firmly workout as well although not as much as the upper body but you will be able to notice the difference when you work out consistently. One of the better benefits of a rowing machine is that of calories burning but few use it mainly for that purpose as other fitness equipments such as the Nordic Track, stationery bike and treadmills can do so effectively. In addition to, the rowing machine can help to improve lean muscle mass and given that lean muscle mass burn off more calories for a given size, the body will utilize more calories to nourish the muscle. As a result, rowing machine effectively increases metabolism so as to feed the lean muscle with the requisite calories. Very few people know that rowing machine help to reduce the stress level and anxiety through the frequent use of it. Exercising makes a person less depress and edgy and it is one of the most beneficial and least appreciated of all the rowing machine benefits. Keeping our mental faculties alert and well is as important if not more than physical aspect of our health. To derive all the benefits mentioned, we need to effectively make the most out of the rowing machine. The information that we gather here will be very relevant to utilize the most from the rowing machine. Fully understanding the machine itself and its functions can contribute to us getting a complete and beneficial workout. Rowing machine mimic the actual rowing experience of a boat for the sole function of aerobic and strength training workout as well as for those training for rowing. The machine has been in existence for more than a century but only in recent years that it gains in popularity. The market for rowing consists of a few types of resistance and they are the air resistance, piston resistance, water resistance and magnetic resistance. All are equally effective and none can claim to be better than the others. Each has their own admirer and the types of resistance you choose will hinge on the relevance of your exercise as well as the state of your fitness level. To derive the most out of the rowing machine, you need to know the different types of resistance levels and the air resistance will increase in resistance as you increase your pace. The piston resistance is the most popular as it is so small and compact that allows the machine to be foldable and move around as well as easy storage. Water resistance comes close to the actual rowing experience and the workout is as intense and the magnetic resistance makes use of electromagnets which make it very smooth and quiet in operation. With lesser noise, similar to air resistance, it provides a great workout without disturbing other. Besides understanding resistance levels to fully utilize the rowing machine, the other extras are as important. The computerized digital display that provide all the functions of the rowing machine such as calories burned, distance covered, time and speed to better gauge our training. All these may come at an additional price but all is worth it. Rowing machine remains one of the best fitness equipments out there and with regular workout, the results are there to see.
Dec 01, 2008 | Kettler Rowing Machine Kadett Rowing...
Exercise & Fitness Logo
252 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
