Question about Homelite Garden
My husband has a Homelite XL-2 chainsaw and the muffler came loose - what kind of a tool do you use to tighten it.
  • sknopp Apr 13, 2011
    You solved the problem for my husband - thanks again
    Scholar:
  • 54 Answers
I think this is an older model similar but lighter than the good old CF 55. It may have two screws of #10-32 size thread on the top and bottom of a small narrow muffler that has lots of horizontal slits. It is best to replace these with SHCS socket head cap screws of the exact same length and pitch of thread and try to use some locktite blue thread lock fluid to keep them in there. Beware there are lots of different screw pitches used like 10-24, 10-32, 1/4-28 so you have to have an old one to match up when buying two new ones. Reverse it and see if it goes into the threads of the new screw beside it. These SHCS screws have the best thread and will use an allen key in english size. Larger hardware stores will have all this stuff and even seperate allen keys for that size only. If they are left loose they kill your ears, and can strip and then you can never get them tight again. The material is quite week so be very sparing on the tension after it bottoms out on the muffler, a half turn of tension can sometimes be all you can do in cast aluminum.
Posted on Apr 10, 2011
  • sknopp Apr 11, 2011
    Thank you for your information.
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Homelite xl chainsaw e-ring on bar tightening bolt needs replacing. Where does it go and how do I do it
The original Homelite company has been out of business for many years. Getting parts for them at our repair shop is impossible. I know you can go and buy new Homelite units from the big box stores, but these are not being manufactured from Homelite. Sometimes you can find parts from repair shops that have leftover parts. You might want to call around. You might find them. George
Oct 07, 2013 | Homelite Consumer Products 9.0 Amp, 14 In....
What fuel mix does a homelite xl-130 chainsaw require?
the homelite xl-130 gas/oil ratio is 32:1 meaning one quart of gas and one oz of 2 cycle engine oil or one gallon of gas and and one 4oz bottle of 2 cycle engine oil.
Best,Regards
obliqueridge
Nov 10, 2010 | Homelite Garden
I have a homelite xl-12 . It runs but the muffler discharge is moist with what seems to be oil . Is it a carb setting prob. seal or ring prob. or a fuel mix prob. ? Thanks a bunch
This is likely a long term situation that occurs with either, incorrect premix, incorrect oil being used in the premix or the motor is running too rich. The discharge over time, will clog the exhaust and the engine will become more and more difficult to start. To fix:
1. Rebuild your carburetor. This is relatively easy and the cost would typically be less than $15 as a DIY.
2. Tune the carburetor (especially the 'H' high speed jet) at wide open throttle (WOT) to get the engine to the highest RPM's then back it off about 1/8 turn
3. Replace spark plug
4. Clean air filter with soap/water and lightly spray with oil.
If you are unable to clean the inside of the muffler, replacement may be necessary depending how clogged it has become.
Sep 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have an old Homelite XL chainsaw that still works but that could use some carburetor adjustment because it frequentlyshuts down between cuts. I do not have a manual and I did not see one listed. ...
The H jet needle should be set so that the engine will 4-stroke at full speed, but immediately 2-stroke when cutting. The L jet needle should be set so that the engine will 'follow the throttle', but idle fairly well. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Check the fuel lines for condition and the fuel filter, air cleaner, and muffler for plugging. Make sure the carburetor fasteners are tight. Hope this helps!
Sep 07, 2010 | Homelite Garden
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
HAVE OLD HOMELITE SUPER XL AUTOMATIC NEED ON OFF SWITCH AND MAGNETO , WE HAVE NO SPARK AND HAVE DONE ALL THE OTHER THINGS . SER. NO 3G2550042 , THE NUMBER ABOVE THIS ONE IS , UT NO 10045-C
Is it this one? She has points.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
You may find parts for this grand old Lady here:
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
Last chance try here (parts and guidance):
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics and saw retailers thrown in. They are a good bunch and I am certain someone can help.
I did not see any Homelite (most makers have one) thread but did find this:
http://www.arboristsite.com/showthread.php?t=120583&highlight=xl+super
Be kind to her. HTH
Lou
Jan 18, 2010 | Homelite Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
CHAINSAW NOT CUTTING PROPERLY
Sounds like your chain is too loose, try tightening it.
Jan 05, 2009 | Dremel Variable - Speed Multipro Rotary...
Garden Logo
128 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
