Question about Ovens
Wiring diagram for halogen ring on belling 636 cooker
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: halogen ring not working
Hi .
It sounds like the temp control is faulty.
Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
Sometimes you can see if the element has gone, .
If you need any further help, let me know.Good luck.
Posted on Nov 23, 2008
  • 250 Answers
SOURCE: I have a stoves cooker
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Posted on Aug 20, 2011
How do I change the fuse on my Belling solid ring cooker?
If 2 rings are not working, then it is probably the rings that are faulty
It means testing the rings with a meter.
Feb 25, 2015 | Belling Ovens
Creda problems
Hi, if there is no regulation on the hob, it is typically the switch that is faulty unless halogen, then it could be the thermal cutout.
warmest regards
Richard The Repairman Colchester Oven Cooker Washing machine repair
Mar 30, 2014 | Creda Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Hi, I have a Belling gas cooker, the oven and grill are working fine but there is no gas coming through the rings at all. Could someone tell me what the problem could be and would it be expensive to fix? ...
I'm not a cooker expert, but try the following. Get a bit of electrical flex, strip the covering and part it so you have one fine strand. Poke this into the tiny hole in the centre of the jet underneath the ring and jiggle it about. The jets often get blocked by grease or a bit of dirt in the pipe same as the washers on a car. Costs nothing to try.
Jun 13, 2011 | Ovens
Oven never worked only two rings on top working.new item.
It may be that it has not been connected properly,there are links in the connection box for different hook up procedures.Either get your electrician or check yourself with the manual that came with it or look in connector box and see diagram relating to these links.If not connected properly only half the cooker will work.I do hope it is as simple as that and you do not have any other serious problems.
Hope this helps.
May 24, 2010 | Belling XOU250 Electric Single Oven
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Dec 30, 2009 | Belling Ovens
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
Halogen ring not working
Hi .
Nov 23, 2008 | Ovens
WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Sep 28, 2008 | Belling XOU174 Electric Single Oven
Ovens Logo
76 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
