Question about Dell Inspiron 1525 Notebook
Computer won't turn on. when i push the start button all the lights flash as if it is going to turn on...including the fan, then it all stops except the single (maybe the power) light stays on. the screen remains dark. Dell Inspiron 1523
    President:
  • 3,278 Answers
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
But, it's also possible that the heatsink may need new thermal paste applied or the motherboard may need replacing.
Leave it to an expert if you are not familiar, for the power jack, heatsink and motherboard problem.
Hope this helps.
Posted on Apr 09, 2011
I can't descale my C5
You may need to go into program mode and "tell it" you replaced the filter. We normally do this when we replace water filters in Jura's. On the f60 you get into program and scroll using the water volume dial and push it in to set the changed value.
Hope this helps
Jan 25, 2013 | Jura Impressa C5 Automatic Coffee Center...
My mitsubishi flashes a red light what does that mean
Red light is usually lamp indicator---may be time to replace the lamp--they have a 2000 hour life span except for generic ones which last half that long----when was lamp last replaced? also the set does have a self check:
After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 30, 2012 | Mitsubishi WD-60737 60 in. HDTV
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
2003 alero steering won't lock and nothing happens when you turn the key in the ignition
If the security light keeps flashing,you might as well do a reset.
Be sure to turn off all the accesories including the radio before you start the process.
Insert the key to the ignition switch and turn the key to ON position without starting the car.
leave it ON until the flashing light (security) stops.It will take approximately 15 to 20 minutes.
As soon the flashing stop,turn the key to OFF
position and start the cart.
Hope this help.
Jul 23, 2011 | 2003 Oldsmobile Alero
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
How to turn change oil light
iI you mean 'how to turn change oil light off" go to fuse panel. Open drivers door there is a panel cover on the side of dash board, remove cover there is a red RESET button that resets oil pressure and tire pressure. Turn the ignition key to the on position but don't start the car. Now press and release the reset button the change oil light should start to flash, now press and hold the reset button until you hear chimming hold until chimming stops then release, the change oil light should go off. If you need to reset tire pressure press reset button twice, the first push will make the change oil light flash the second press will make the tire pressure light flash then hold untill chimming stops, light should go out . Hope this helps.
Sep 30, 2010 | 2000 Pontiac Grand Am GT
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dell Inspiron 1525 Notebook Logo
Alun Cox
