Question about Sony Walkman WM-D6C Personal Cassette Player
Sony Walkman WM-D6C
The playing speed is too fast and cannot be adjusted by the speed control. Please help!
  • 1 more comment
  • turbotk2001 Sep 12, 2008
    I have the same problem. It happened suddenly. Can anyone help please?
    Todd in Austin, TX
  • captnhanky Feb 08, 2009
    giles becket:
    What do you mean with pin 15, the ic 601 has only 8 pins!
    I have changed the ic with another one that is working, but the problem still exists...
  • tseib Apr 22, 2009
    I bought a used WM-D6C online--Wonderful cosmetic condition, but suffering from the high-speed playback issue. I am getting 5.8 volts on the pin 15-to-ground reading (vs. the 4.8 volts GB suggested), and the "pick up coil on the main flywheel" test is giving me 638 ohms--right in the range GB suggested was okay. Any other ideas what could be wrong?
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
If it's a problem with the electronics then a professional repair will be needed ... however, there is one possible mechanical cause that can be investigated ...
Check that the little rubber pinch-wheel is clean (cassette cleaner with dilute isopropyl alcohol is best) and more importantly check that it is fully engaging with the capstan and squeezing the actual tape tight enough.
Without the capstan and pinch-wheel working properly, the take-up motor/drive will just pull the tape past the head really quickly.
Good luck.
Posted on Jan 09, 2009
Hi I have the same problem can anyone help please
Posted on Oct 24, 2008
New tape playing too fast. What do I do to slow it to normal speed?
You have to replace the IC 601, probably burns because of some passive components that must be replaced. "Doctor.walkman @ gmail.com"
Nov 21, 2010 | Sony Walkman WM-D6C Personal Cassette...
Speedproblem. My wm-d6 walkman goes way to fast! More than twice as fast normal speed 4,75cm/s. Is there anything I can do about it myself or is it a component failing? /Mats
Inside the unit, theres a capacitor or something on the circuit board that has a little phillips head screw area on it, that if you turn it either clockwise or counter clockwise, you can adjust the speed of the cassette playback. This is usually a silver metal thing sticking up somewhere inside kind of shaped like a letter "U'. the inside of the "U' is a round insert like I said with a phillips head screwdriver cut out. just turn that inner piece left or right while playing a cassette to your desired speed.
Nov 08, 2010 | Sony Walkman WM-D6C Personal Cassette...
My Sony Walkman Professional WM-D6C will turn on but the take-up spindle just slowly inches the tape along in short bursts, not a continious action.
Contact me at my email doctor.walkman @ gmail.com, I'll ask you some questions and some photos of the WM-D6C in his possession. We will solve the problem
Apr 23, 2010 | Sony Walkman WM-D6C Personal Cassette...
While trying to rewind or fast forward, it stops before reaching the end, and I have to restart it.
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Dec 10, 2009 | Sony Audio Players & Recorders
Sony Walkman cassette tape player operating at slower speed
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email eledocs@hotmail.com
Mar 31, 2009 | Sony Walkman WM-D6C Personal Cassette...
Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Feb 23, 2009 | Sony Walkman WM-D6C Personal Cassette...
Plays too fast
WMD6C has a pitch control on the back of the unit that can change the speed of the tape, so switch it off, but if that is not the problem then inside the unit it has a servo set speed pot on the main board.
Nov 08, 2008 | Sony Walkman WM-D6C Personal Cassette...
Sony Walkman WM-D6C Personal Cassette Player Logo
3,657 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
