Question about Hyundai ImageQuest L90D 19" LCD Monitor
My monitor screen goes blank intermittantly for a couple of seconds then comes on again. Very annoying when typing or reading. I have just bought a new computer running Windows 7 and the monitor is not recognised as "Generic" and "Make unknown".
3 Suggested Answers
  • 63 Answers
SOURCE: flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor http://www.hyundaiq.com/Eng/Customer/CusSvc/Csvc.asp
Posted on Aug 27, 2007
SOURCE: I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Posted on Jan 31, 2009
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Open Questions:
Hyundai ImageQuest L90D 19" LCD Monitor Logo
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
