Question about Sharp EL-1601T Calculator
How do I get the paper to load? I try to start it thru the slot on the back of the calculator but it won't feed through even though the calculator runs and paper axels spin. This is on a EL-1601T printing calculator.
4 Suggested Answers
SOURCE: I'm trying to load paper into a Sharp el-1701c that I inherited.
My wife solved it by finding a thin little slot on the back of it where you put the paper in. Worked
beautifully. Thanks any way.
Posted on Dec 20, 2008
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
SharpCSR
  • 11 Answers
SOURCE: how do I thread the paper tape to the machine
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
How do you load the adding machine paper on this calulator #P23-DHV Cannon
Paper loads into slot at end of machine. After inserting end into the slot (at rear, near power cord connection) press feed button until paper advance thru top.
Jul 05, 2010 | Canon P23-DHV Calculator
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Dec 19, 2008 | Sharp EL-1701C Calculator
Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Jun 20, 2008 | Canon P23-DHV Calculator
Register tape
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 13, 2008 | Sharp EL-2192Rll Calculator
Loading paper
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Aug 15, 2007 | Canon P23-DH Calculator
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
I'm so stupid
  1. Remove the top gray lid of the calculator
  2. Insert paper through the back side slot near the power charger
  3. Turn the calculator on print
  4. Press FEED a couple times
Feb 26, 2007 | Casio HR-100TEPlus Calculator
Sharp EL-1601T Calculator Logo
20 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
