Question about Estate Dryers
I was cleaning the lint catcher while the dryer was on and dropped a washcloth into it. How do I get the washcloth out?
    Sergeant:
    Champion:
  • 207 Answers
First unplug the unit then remove lint trap then try a stiff wire with a slight curl hook on the end a hanger will do its a smooth chamber push it till it hits it or tuches the bottom twist the wire pull it should come out,if this dont work u half to pull the back of and pull the dryer vent filter tube off with screws at the bottom and it should be there..
Posted on Apr 09, 2011
My gas drier shuts off before clothes are dried
Also it can be a few other issues:
1: It could be an issue with the lint catcher. Take the lint catcher out, clean off all the see-able lint, then take it to the bathroom and try to run water through it. If the water settles or doesn't run through very well, take an old toothbrush and scrub that clean under water until water passes through easily. This issue caused my dryer to shut off without being dry too
2: Depending on how new your dryer is, it may have a dryness sensor in it. That sensor may not be working well or at all causing the problem as well.
3: Finally your heater could be going out in your dryer and causing it to hot get hot enough in the time you set for the clothes to be dry.
Hope these 3 things help you.
Mar 26, 2015 | Dryers
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Is there a way to access the area under the removable lint catcher or should I just use a hanger
I have successfully taken the front of that off and cleaned it out. However, it isn't easy and I could see where it may result in a broken lint catch if not careful. After taking the front panel off - which is a pain in and of itself - you will need to carefully go around the lint catcher and separate it. It is in two halves that are held together by catches all around.
Sep 25, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
BOSCH WTE84100 CONDENSOR DRYER .will not start .Power display on and flashing ,all filter are clean, but machine beeps when try to start.
Two Beeps means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Aug 15, 2011 | Bosch Dryers
Clothes are now taking much longer to dry. I have cleaned the dryer vent & vent hose. ( all the way to the roof as I did once before that rectified the problem then.) Wet lint is around the door and...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
Dryers Logo
49 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
