Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Model 4KSB5WH3 120 volt 4.8 amp. kitchen aid ultra power blender rotating piece on base (black) shirley_c_b@hotmail.com
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: spare beater
http://www.marbeck.com/mixers_kitchenaid_parts.html
heres link for replacement parts
my recommendations i would go with new parts but some will like to do the work them selves
Posted on Jun 11, 2008
SOURCE: Kitchen aid mixer, voltage issue
Why not just buy a power converter for the mixer and other electronics on Amazon. They are cheap and can be adjusted for
110 - 240 and can be used anywhere in the world.
Posted on Jan 16, 2009
Kitchen aid mixer 5kpm5 motor doesnt go round freely
Any appliance with a motor should rotate freely. These are basically gear driven devices, Kitchen Aid makes different quality equipment. So either the gears are worn or possibly if you notice an electrical smell the problem could be at the tail of the motor. there are 3 major components 1. the brushes where the armature spins if you look inside the vent holes you might see a slight arc while it is running 2. the tail piece which is how the motor is kept straight. or as I said worn gears. this is especially common when companies use plastic gears instead of metal ones. Commercial appliances made by people like Hobart are expensive, but they outlast most others..
Apr 09, 2013 | KitchenAid 5kpm5eer Pro-Line Heavy Duty...
No power to my kitchen aid mixer
please i need help kitchen aid mixer i have no power
Jun 27, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen Aid Stand Mixer (model 4KSM90OB) won't run.
Sounds like you have solved it already, the phase boards are worth stuff all so buy one and throw it in. It's unlikely to be much else as you have proved the motor runs.
Mar 20, 2017 | KitchenAid KSM103 Professional 5 Series...
Makes noise when on but the blender doesn't turn.
It is most likely a stripped gear. Here is a link to the parts manual which contains the listing of the gears and shows you how to split the gear case.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
Remove the chrome ring with a screwdriver by prying it off carefully. This exposes 5 screws, however they can't be accessed on all models. Remove the pin (17) that goes through the planetary housing and the drive shaft, and carefully drive the planetary housing from the shaft to expose the screws. Then remove the 5 remaining screws and split the case to expose the gears. The worn gears will be obvious.
Also check the bearings. Replace all affected parts. Remove all grease since metalic pieces will have contaminated it from any worn out gears. The grease is a special food grade grease which you can purchase along with the gears and bearings.
Apr 11, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Tipped over my blender, broke the black plastic piece that raises and lowers the top, and now it is stuck in lower position. Won't move.
Blender? This is a form about Kitchenaid mixers . . . assuming that's what you have,and it is a stand type mixer, look at this page:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
And you will see the linkage which was bent/broken. Hopefully you will be able to either straighten the bent part or replace it if it is broken.
Mar 27, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
No problem just need a manual for all the parts of a K5ss mixer
Hi AUER24, you can easily download both the Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
This particular manual provides both domestic US and International Part numbers, which you will want to use, based upon your 220 volts rating that tells me you have an international model.
For future reference, here are five potential USA vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Also, here are some links to three excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 18, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Spare beater
Jun 04, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
383 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
