Question about Car Audio & Video
Hi my van ldv maxus have cd player and radio CD423 the battery gone flat now i do not have a code for it. is someone can assist me
    Sergeant:
    Champion:
  • 207 Answers
Have u tryed the common standerd 1234 2345 numbers if not try it also call a dealership for info from the parts department ask for help then they should send u too somone else if need be...
Posted on Apr 09, 2011
Today i bought ldv maxus van 3.5 2005 keeps jumping out 4th gear
will assume a used van
any warranty ? go back to place of purchase
if a manual ..worn syncros or adjustment to shifter cables
if an automatic a shift soleniod or worn drive clutches
Oct 12, 2016 | Cars & Trucks
LDV MAXUS 2.5 DIESEL DIAGNOSTIC FAULT CODE P1145
The owner's manual should have code information if it is equipped for self diagnosis, Like the Chrysler (Limp mode self diagnostic system)
Chrysler and some Mitsubishi models prior to the split, Those codes can be found @ Allpar.com or the manufacturer's website for most others, If a friend or someone you know lets you borrow a code reader, plug in after you set the parameters and the code you read might be different for that model but should lead to a solution.
Dec 02, 2013 | Motorcycles
How to fix 5th gear on my ldv maxus
Its likely you have a problem with the clutchnot completly disengageing or problems with disk or pressure plate
Jun 13, 2013 | 1997 Chevrolet Cargo Van
Need a radio code for ldv van
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Apr 10, 2013 | Televison & Video
Help!!! how to reset a LDV Maxus key fob?
Hi
I know from experience that you cannot really re synch these fobs on the LDV Maxus vans.
What actually is the fault is an onboard component on the pcb has failed and we normally just replace that with a new one..the fob will be tested for operation and sent back. OR its the Relay in the ESA unit - under the left hand front glovebox on the bulkhead - black with cables going into it. We have those relays (soldered to the pcb) we can supply those or do the work for you. The fob connects to that ESA and the unit then fires the relays to open/close the doors. Sometimes that unit is installed upside down which causes water (condensation) to enter the box and have fun with your electrics.
The fob is SYNCHED to this unit via coding we can use your old fob to clone to a new fob and that will work with the ESA and the vehicle.
We have the parts on this link Items for sale from remobilise ltd
Here is a link to how to program the fob to the vehicle via the programmer - NOTE how you MUST have a working fob to program another (text at the start of the video... LDV Maxus flv
We can fix most problems on the LDV Maxus that occur with faults to do with the Central locking/fobs/ESA/ETACS - three relays are in the ESA and they control ONLY the central locking - two more relays are in the ETACS unit (behind the ashtray) and they control the fogs and intermittant wipers.
Any help or info needed please contact info@remobilise.co.uk
or tel 01792 896404.
We are based in Swansea UK.
Aug 30, 2012 | Cars & Trucks
LDV Maxus
Please re post this in the car and truck area as this is listed in the DVD area.
Jun 16, 2012 | Televison & Video
I have a LDV Maxus Van, The problem is it only starts with a tow and then runs fine and the minute i turn it of it needs a tow again
Hi have you had any joy finding fault I have the same problem with my Maxus. I've replaced endless stuff even main pump ,narrowed it down to crank position sensor.but sensor is fine there should be a 5v feed but there isn't one ,checked wire back to ecu and its ok. But carnt see it being fault on ecu van drives and performs great once running. Seems to be quite a common thing on these but no one seems to have an answer, if you have any joy with yours or need any questions over it you can contact me on d-scott13@live.com for number , cheers dave
Dec 09, 2011 | Chevrolet Venture Cars & Trucks
How do you program remote central locking on ldv maxus as the remote is sending out a signal as we ahve had this checked but it doesn't lock or unlock the van
it sounds like its either the fob or the esa unit if its the unit it needs to be programmed by an LDV dealer using the diagnostic equipment
Feb 16, 2010 | Vehicle Parts & Accessories
How is the central locking meant to operate on an LDV Maxus Van
the central locking can be programmed to either unlock and lock all of th edoors together or by opening the drivers door with the first press of the fob and then unlocking the doors with the 2nd press. the load doors will then lock after a pre determined time for security
Oct 21, 2009 | Vehicle Parts & Accessories
Car Audio & Video Logo
541 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
