Question about Poulan Garden
PPB150E Start with shaft in horizontal position. Let run in horizonal shaft position a trottle in start for position for about a minute and it dies. Hard as heck to get restarted. New gas. Before today last use was last summer.
    Brigadier General:
  • 3,917 Answers
Hi
It is suggested to check the compression. You will need a compression gauge to check the compression; you should have at least 90 PSI of compression. If it is fine then it could be a carb problem or an air leak. Check around to engine for any signs of accumulated dirt or oil; this is a sign of an air leak.
Many times the rear engine gasket/o-ring will leak. Remove the rear engine housing cover, inspect the gasket/o-ring. Usually some gasket sealer applied to the gasket/o-ring will seal the leak.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 09, 2011
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
I have a 88 Plymouth horizon was running fine And all of a sudden I turned the key on and nothing happened I changed the battery new ignition relay and still nothing can anyone tell where to find wiring...
Try holding key in start position while moving shifter slowly through all gears to see if you get a click or start at all. Safety neutral switch/back-up lights on transmission were known to cause that problem.
Feb 28, 2015 | 1988 Plymouth Horizon
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES: a. The horizontal registration assembly is out of place because of
damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the
presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the
sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty. Replace the motor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
1990 Sierra, runs fine then just dies and will not start till pri
Did you change the fuel presure regulator located in the throttle body?
Nov 01, 2017 | 1990 GMC Sierra
2003 honda gl 1800 goldwing
1. CHECK THE MAIN FUSEAND FI INGN FUSE IF OK THEN GO TO 2.
2. MAKE SURE ENGINE STOP SWITCH IS NOT ON.
3.MAKE SURE THAT FI RELAY IS CLOSING. TURN ON KEY SWITCH AND THE FI LIGHT SHOULD COME ON. THEN CHECK TO SEE IF 12VOLTS IS AT RED/WHITE WIRE COMING FROM RELAY ( RELAY IS UNDER THE SEAT)
NOW IF THIS SO YOU SHOULD HAVE SPARK AT THE PLUGS. IF NOT SOMETHING IS SHORTING THE ENGINE CONTROL MODULE. MAKE SURE THE BIKE IS IN NEUTRAL
AND THE IGNITION PULSE GENERATOR IS GOOD
Feb 12, 2009 | 2003 Honda GL 1800 Gold Wing
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
