Question about Music
What kind of cable do you need to connect a Kurzweil K2500S to the amp?
  • 3 Answers
Hi. You can use standard 1/4 inch jack to jack audio cables (ordinary guitar leads will work fine) to connect the MIX outputs to a keyboard combo amp. If the amp only has a mono input, just use one cable from the MIX output marked L to make the connection. Remember to keep the amp volume turned down until you have plugged in the cable(s) from the K2500S. All best.
Posted on Apr 09, 2011
  • 1 more comment
  • djwhite153 Apr 12, 2011
    Thanks!! Now I got everything hooked up....turned the keyboard on and still NO SOUND. The display is lit, but has no writing (ie sound choices) displayed. What now to get some sound?!?
  • Nicolas Rowley Apr 12, 2011
    Do you have the reference manual and the performance guide? You can download them from the web.
    I suspect you may need to adjust the display contrast as described in the manual (see below) to see and select the patches. Let me know how you get on. All best
    Adjust the display contrast with the Contrast parameter in Master mode. If for some reason you have trouble reading the display, even after adjusting the Contrast parameter, you can also adjust the contrast by holding down the ENTER button and turning the Alpha Wheel. If this improves the contrast, immediately return to the Contrast parameter and adjust it slightly. This will cause the K2500 to remember the current display contrast level, and should take care of any difficulties you may have been having.
    If this doesn't help, you can try pressing the +/-, 0 and Clear button at the same time. This is called a soft reset. As a last resort you can hard reset by pressing the Master Mode button then the Reset "soft button" on the lower right of the display.
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Kurzweil M1 digital piano is resetting (shutting down and turning on) on its own in the middle of playing.
You're correct, that's a power supply problem, but it may also be the power supply connector on the keyboard. If you have access to a voltmeter, check the power supply first.
Apr 06, 2016 | Kurzweil Music
I am looking for a manual for the Kurzweil Reader Model 7315-60.
Your best bet would be to contact Kurzweil Customer Service directly.Here isa link to their Support page-
Kurzweil Education
Feb 23, 2015 | Music
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
Kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Sep 25, 2012 | Kurzweil Music
I NEED KURZWEIL PC2X MANYAL
http://kurzweil.com/content/migration/downloads/pub/Kurzweil/Pro_Products/PC2/DOCS/PC2V3MAN.ZIP
May 06, 2012 | Music
I have a Kurzweil Mark-Pro TWOi. It takes several minutes to turn on, and keeps resetting and clicking while booting up. My guess is a bad capacitor somewhere. I looked at the power board, and it looks...
I don't know what you "tested" the power supply board with, but I would use an oscilloscope to look at the outputs to see if any of the regulators are drooping. Clicking is a broad term... if it is a relay, it PROBABLY is for speaker protection and senses balance of the power amps.
With a two minute delay, this is PROBABLY a thermal issue... Use freeze mist/circuit cooler to find suspicious parts.
Jan 01, 2011 | Kurzweil SP4-7 76 Note Digital Stage...
Music Logo
389 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
