Question about Dryers
I have. Maytag legacy dryer that stoped spinning I replaced the belt, the old one was fraying n cracked n streached out. The moter spins but the bel I s not turning the drum. Any ideas??
    Sergeant:
    Champion:
  • 207 Answers
Check the roller wheels on the back of the drum they might need replacing there usally at the bottom against the back of the unit also duoble check how u hooked up the belt once i thought i put a belt on it was wrong the spring should be tight...
Posted on Apr 09, 2011
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Maytag legacy series dryer starts and spins but will stop spinning after a few minutes
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | Maytag Dryers
Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Mav6260 washer will not spin
the belts on these units will streach, and alot of the early unit had bad belts.
the unit should spin with or with out water in the spin cycle
also the thrust bearing on these units go bad often.
this is a magic chef washer with the maytag name on it.
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
My washer will not spin off the water
Check the drain hose and make sure it is not plugged or kinked. Check as well that pumps spins. Good luck
Aug 19, 2007 | Maytag Legacy Top Load Washer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
